Got the new front bumper done
Discussion in 'The Garage' started by Blazr77400, May 17, 2006.
  1. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    I decided to redo it since I plan on doing an Exo-cage.
    I used 1-3/4, .120 walll DOM. About 30ft of it.
    2x2 square tube with two 3/4" bolts and two 5/8" bolts hold it on.
    The clevis hooks are 3/4".
    This is the first project with my tubing bender.
    I also widened my hummer wheels 3".
  2. tiny2085
    tiny2085 1/2 ton status
    May 14, 2004
    160
    Two-will-uh
    is just me or does it look like the bumper corner is touching the tire in the second picture?.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks can be decieving.
    very sweet man! why did u change bumpers? old one looked sweet too!
  4. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Its just you.:D
  5. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    I just can't get enough of that truck, pure secksy!! :pimp: :bow:
    Be sure to post up the exo progress. :wink1:
  6. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Here are some of my ideas on the exo.
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Nice Rig! I am checking out the build pictures. Great work and originality!
    Oh, I sent you a PM.
    DP
  8. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    after looking at your pics of an awesome truck. it looks like there's just a square metal tube that just holds the ram and isn't connected to the front-end. is that the case? and if so, are there any problems when the suspension flexes?
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    What is the square tube going from the axle to the bumper for?
  10. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    I'll bet you it's an anti-wrap bar for the front end.
    Mog axles + Leaf Springs = Lotsa Wrap
    :usaflag:
  11. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Here is little bit better picture of the front end.
    The square tube is an anti-wrap bar. I used Square tubing because thats what I had at the time. I plan on changing it up a little bit, but for now it does its job. No wrap and it still travels pretty good.
  12. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    Awesome! and incredible truck :bow::bow:. What did you do with the old bumper?
  13. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Sold it to my brother to pay for some of the tube, he was to lazy to build one for his blazer.
  14. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Thats a sweet ride for sure..........We should go wheelin sometime.
  15. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Im down for some wheeling. Might go to Jericho over memorial weekend.
  16. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    That is one sick rig! I dig the front bumper, I guess with a truck like that you don't need a winch ;)
  17. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    Front and rear steer or just front?
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    since the differentials are centered, how does that work with the offset of the t-case?
  19. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    How did you make the clevis mounts?
  20. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    The rear axle is a steering axle, but its locked out for now. I am just waiting for someone to donate the steering, and donate a winch, but nobody has yet:rolleyes:
    The differentials are offset 3 inches so the rear drive shaft is just a standard 1350 u joint. The front is a totally different story. Its a H.A.D. dual 1350 cv. It has a cv on the pinon and the transfercase. The main reason I did that was to get rid of the vibration so I could drive it on the street. If I never drove it on the street I could of just used a regular U-joint on the pinion. There is plenty of clearance with the oil pan and trans pan, but the 203 and adapter are way close, like an 1/8". I actually had to grind some of the adapter and the 203, and then cut half of the drivers side t-case mount bushing off(make sense?)
    The clevis mounts are just 1" 1018 that I waterjetted out.
