got the rock ram in today (Pics)
Discussion in 'The Garage' started by highrider_44s, Jul 23, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i finally got around to putting the ram in today /forums/images/graemlins/thumb.gif after a lot of /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif in the hot sun (truck wont fit in shop anymore) she's finally in i think it turn out all right so far everything works
    need to make final adjustments tommorow maby still modify the pump /forums/images/graemlins/dunno.gif
    heres the ram mounted
    and heres the box all taped and mounted
    didn't get any final picks because it got dark out
    but all in all in took it for a drive drives good still needs a final tweak or two /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Sweet, I just got mine in too. Ain't the great. Its so nice to be able to turn my tires /forums/images/graemlins/thumb.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Cant tell from the pic but did you weld a mounting tab on the draglink or is it a clamp?
    What ram did you use?
  4. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    i welded it on the tabs on both ends
    i was going to bolt it to the drag link but it would have
    been a pain in the ass. besides the weld would probably be alot more solid /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
    the ram is a 8' stoke 2 inch boar i bought it from
    princess auto
  5. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    ram looks good man! it looks like your springs are toast tho.
  6. 1-ton
    Apr 17, 2004
    2,890
    166
    Las Vegas, Nevada
    Your right, they look bent.
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Did you tap your box yourself? Looks good, also how much did the ram cost you if you don't mind telling /forums/images/graemlins/whistling.gif
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    uhhh your panhard bar is kind of running the wrong direction. When the suspension compresses the panhard bar is gonna push the suspension one way and the drag link is gonna be pushing the other way. If you mounted it reverse of what you have they would travel together and no bump steer.
  9. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    yea i did tap it myself wasn't that hard
    the bottom hole was the hardest bacause the tap was tapered i found that if you drill through and partway into the otherside of the gallery you had enough room to get the tap in far enough as well as it acts a little resivor in behind the fitting /forums/images/graemlins/thumb.gif
    the ram was just under a bill /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif (this is canadian)
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thats what I have been seeing also....will be upgrading shortly after m x over is done /forums/images/graemlins/whistling.gif
  11. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    yea i don't know what i was thinking when i put that in /forums/images/graemlins/doah.gif
    i think i was looking at it in a different way
    probably be the next thing i change
    does it matter if the panhard bar is a different length than the steering bar /forums/images/graemlins/thinking.gif will they travel different distances or will it be minnimal
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    took you damn long enough....
    hows the fam?
    u need anything from your folks place?
    Grant
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it would be minimal, the panhard should be on a very similar angle to your steering drag link, that is the most important thing(well that and that it goes the same way /forums/images/graemlins/wink.gif)
