Got to play a little (56'ers still good to me)
Discussion in 'The Garage' started by SCOOBYDANNN, Nov 14, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Got to play a little around the local test spot. I need to either lift the front a little more or build a bumpstop/engine crossmember as my hydro ram has feelings for the oil pan--it really only happens in the fast stuff when i hit unintended dips in the road, but none the less.
    the flex is completly amazing, and i dont know if I did it right but the stock front driveshaft is still holding up--all i did was ground off the ears on the CV.
    I even got my first 2 scars--the front pass side by the light and pic # 3
    the hole is bigger than it looks. It will swallow a 35 no problem.
    even got to pull out a jeep that got stuck going down hill:haha:
  2. goldwing2000
    goldwing2000 Guest
    How the hell do you get stuck going downhill??
  3. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I guess its a Jeep thing:whistle::haha:
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its a rubicon too.....
    are those stock 56's up front or lifted ones? i cant wait to get my lifted 56's up front. looks good man!
  5. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    stockers--what kind of lifted ones did you get---im thinkin of this option rather than some 52's
  6. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    that place looks like fun, and i like the front end of your truck and it flexes really well
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Any plans for high steer?
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to go with TC 4" 56's or maybe 6" 56's and remove the overload since i will be running a 6.2, i can get a new set for $240 shipped through advance auto parts, and then run reverse hi-steer. its weird, when i looked the part numbers up at the store, the 52's were $20 more.
    any idea what ur get on an rti? what springs are you running in the rear? your flex looks really good
  9. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Where is that? Have you been to Ozona yet? We need to hook up and wheel! I havent been out in almost a year.
    PS Looks Great!!!!!!!!!!
  10. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    [hijack]
    They're so low stock it's easy to do... :doah: :o
    :D [/hijack]
  11. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I was running the same rear springs (w/ a springer susp.) and 6" tuffcountry fronts w/ the 42's and i RTI'd over 1000 on a 30. I have no doubts i would match or beat it with the setup i have now.
    The rear springs are 57" ford f150 rears.
    Santa Teresa New Mexico, basically my back yard.
    Nope, The TR is 1.5x.250 cromo. I've slapped that thing into so many rocks and it just keeps going. I know thats the whole purpose but it hasn't really given me a reason to move it. I would also have to figure out what to do the hydo ram as I have it going to the knuckle
    :thinking: im thinking a 2" lift spring would do the job.
  12. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    thats the same "i just spent $xx,xxx and i can't get over this stupid little hill and all my friends are laughing at me" look my friend had:haha:
  13. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    I know that feeling well...
    :rotfl:
  14. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    yup same one, just with a little sadness thrown in:rotfl::haha:
  15. blazin83
    blazin83 Registered Member
    Mar 6, 2006
    18
    atlanta Ga
    awwwwww guys, leave him alone.. he looks a little..uhhmm.. special.
    whats up with the front end of that jeep?
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    for you, probably, im not sure if they make a 2" lifted 56"er tho. im looking to get about 8-9" of lift out of mine to match the rear, so thats why im probably going to go with 4" 56"ers
  17. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    That looks realy good Danny. Thought about doing it to my burb, but the new bumper is in the way. Might have to see if i can modify it some.
  18. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    'ey, Scoob, how's it handle on the street/at speed?
  19. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Other than my TC making noise (needs rebuild) i cruise 70 on the freeway no problem.
  20. JanneB
    JanneB Registered Member Premium Member
    Dec 9, 2004
    62
    5
    Finland
    About those lifted 56" springs..
    I have +4" 56" Pro Comp springs front and rear, these:
    http://store.summitracing.com/partd...tt=EXP~13311 or EXP~13511&Ntk=&rsview=sku&Ns=
    One thing I did not know when I ordered those springs, the main leaf is something like 58" or so. It maybe wouldnt matter whit a small block and no winch but I have both and I want the springs to flex. This means the main leaf is going to be straight (sp?) when compressed. So I had to move the rear frame bushing and make real long shackles.
    But they flex very well.
