Got too codes can you help me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by porkchop, May 5, 2002.
  1. porkchop
    porkchop Registered Member
    Apr 29, 2002
    21
    NH,seacoast
    Ok got the codes of my 87 and they are as follows
    12 & 14
    Can any one tell me what they are any help would be great
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I dont have my Haynes Manual with me, but if you have one they list the codes in there.
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    here ya go
    Code Description
    12 No reference pulses to Electronic Control Module (ECM)
    13 Oxygen (O2) Sensor - signal stays low ("lean") during warm engine cruise
    14 Coolant Temperature Sensor (CTS) - signal voltage is low
    15 Coolant Temperature Sensor (CTS) - signal voltage is high
    16 High battery voltage
    Direct Ignition System (DIS) fault - line open or shorted to ground
    17 RPM signal problem
    21 Throttle Position Sensor (TPS) - signal voltage is high during engine idle or deceleration
    22 Throttle Position Sensor (TPS) - signal voltage is low during engine idle
    Fuel cutoff relay circuit - open or shorted to ground
    23 Manifold Air Temperature (MAT) Sensor - signal voltage is low
    Throttle Position Sensor (TPS) error
    24 Vehicle Speed Sensor (VSS) - signal is constant (no pulsing) during engine deceleration
    25 Manifold Air Temperature (MAT) Sensor - signal voltage is low
    Vacuum Switching Valve Circuit open or shorted to ground
    ATS Sensor - signal voltage is high
    26 Quad driver module
    27 2nd gear switch
    28 3rd gear switch
    29 4th gear switch
    31 Manifold Absolute Pressure (MAP) Sensor - signal voltage is low
    Fuel injector
    Park or Neutral switch
    CAM diagnostic
    Governor Malfunction
    Wastegate overboost
    Wastegate Eletrical Signal - open or shorted to ground
    32 Barometric Pressure (BARO) Sensor circuit failure
    Exhaust Gas Recirculation (EGR) valve diagnostic switch - closed during engine startup or open when EGR flow requested by ECM
    EGR/EVRV (Electronic Vacuum Regulator Valve)
    33 Mass Air Flow (MAF) Sensor - signal voltage or frequency is high during engine idle
    Manifold Absolute Pressure (MAP) Sensor - signal voltage is high during idle [Note: Engine mis-fire or unstable idle may cause this code]
    34 Mass Air Flow (MAF) Sensor - signal voltage or frequency is low during engine cruise
    Manifold Absolute Pressure (MAP) Sensor - signal voltage is low during ignition on
    35 Idle Air Control (IAC) system problem - can not set desired RPM
    36 Mass Air Flow (MAF) Sensor - burn off circuit problem
    Transmission shift problem
    Direct Ignition System (DIS) fault - extra or missing pulses in Electronic Spark Timing (EST) signal
    38 Brake switch circuit failure
    39 Torque Converter Clutch (TCC) circuit fault
    41 Cam Sensor (CAM) failure
    Cylinder Select Error
    Tach Input Error - no reference pulses during engine run
    42 Electronic Spark Timing (EST) circuit - open or shorted to ground during engine run
    Direct Ignition System (DIS) fault - bypass circuit open or shorted ground during engine run
    Fuel Cutoff Relay Circuit - open or shorted to ground
    43 Electronic Spark Timing (EST) Circuit - low voltage detected
    44 Lean exhaust indication - Oxygen (O2) Sensor voltage stays low after on or two minutes of engine run
    45 Rich exhaust indication - Oxygen (O2) Sensor voltage stays high after one minute of engine run
    46 Vehicle Anti-Theft Sytem (VATS) failure
    Power Steering Switch failure
    47 Electronic Control Module (ECM) computer circuit problems - Universal Asynchronous Receiver/Transmitter(UART) link
    48 Misfire
    49 Vacuum leak
    51 Electronic Control Module (ECM) computer circuit problems - Programmable Read-OnlyMemory (PROM)
    Checksum errors
    52 Electronic Control Module (ECM) computer circuit problems - fuel calpac missing, analog todigital converter (A/D) error quad driver module (QDM) fault
    Oil Temperature Sensor - signal voltage is low
    53 Over voltage condition
    Voltage reference error
    Vehicle Anti-Theft System (VATS) problems
    54 Low fuel pump voltage
    Fuel pump relay
    Quad Driver Module (QDM) output failure
    55 Electronic Control Module (ECM) computer circuit problems - ECM failure, Serial Bus error, SAD error
    Fuel lean malfunction
    56 Corrosivity/add collant
    Port Throttle System Vacuum Sensor problems
    58 Vehicle Anti-Theft System (VATS) problem
    61 Oxygen (O2) Sensor degraded
    Port Throttle System error
    Cruise control problems - vent solenoid circuit
    62 Gear switch imput diagnostics
    Oil Temperature Sensor - signal voltage is high
    Cruise Control Problems - vacuum solenoid circuit
    63 Manifold Absolute Pressure (MAP) Sensor - signal voltage is high
    Small EGR failure
    Right Oxygen (O2) Sensor failure
    64 Manifold Absolute Pressure (MAP) Sensor - signal voltage is low
    Medium EGR failure
    Right Oxygen (O2) Sensor - lean condition indicated
    65 Large EGR failure
    Injector Peak/hold Diagnostic
    Right Oxygen (O2) Sensor - rich condition indicated
    Cruise Control Position Sensor Problem
    66 Electronic Control Module (ECM) computer circuit problem - internal reset occurred
    67 Cruise Control - switch circuit problems
    68 Cruise Control - system circuit problems
    69 Air Conditioner Pressure Switch - circuit problems
    88 Electronic Control Module (ECM) computer circuit problem - internal reset occured
    Hope these help
    NITRO
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    you will always get a code 12 when checking codes, the engine isn't running so there aren't pulses coming from the distributor to the ecm, it doesn't indicate a problem. if you had several codes and were reading them out, when you get the code 12 the second time you would know you were through all the codes.
    the code 14 indicates a problem in the coolant sensor circuit, could be a bad sensor, loose contact at the sensor connector or ecm connector, open or shorted wire between the ecm and the sensor.
