Got Wires? :)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CooknwithGas, May 3, 2002.
  1. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I am in the process of swapping the Under Hood wiring harness with a slightly newer version. I recently had a little fire and burned a good bit of my 1975 underhood wiring harness. Instead of doing surgery ont he old one, I acquired a 1977 complete wiring harness (under hood).
    It bolts up just fine and the wires are similar (some connectors are different), and the pins are slightely different, but it plugs in OK.
    Anybody have advice on this. Is it a bad idea? Should I just try to splice and dice on the old, burned one?
    Thanks for any help.
    __________________
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think you will be able to make it work fine
  3. dyeager535
    26,976
    Just have to make sure that the wires that are in the same place in the connector, go to the same place in the engine bay, regardless of color or connector. The wires don't care what color they are : )
    Just be careful that you don't have any "hot" leads just laying around now. For "surgery" a paperclip will remove those connectors from the plug.
