Got zerorate?
Discussion in 'The Garage' started by sandawgk5, Mar 23, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I do:D
    I got these from JKWOFFROAD they have a 10 degree taper and are 1" thick on the narrow end. They will be installed tonight and wheeled on Saturday:D . Also JKW is great to do business with.
    Ira
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    are you gonna bevel the edges so there is no stress points on the springs?
  3. sandawgk5
    Oct 28, 2003
    6,881
    They are you cant really tell in the photo. They have been knocked off with a grinder not machined round like ORDs. I think it achieves the same thing. I have a flap disk that I can run over it if necessary. I will see what Readymix thinks we he sees them. How radiused should they be?
    Ira
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I would round the edge a little more just to be safe.
    They look nice.
  5. sandawgk5
    Oct 28, 2003
    6,881
    Well I ran into a problem with the zerorates. Do to the fact that I cannot afford a new drive shaft with 1410 yokes I bound my shaft at normal ride height. So Brian and I flipped them around to point the pinion angle higher than it was before just to see what would happen. The operating angle of the joints is the same but 180 deg out of phase and at 75 mph there was absolutly no vibration.:D My pinion is pointed up at 23 degrees and I have sufficient oil in the diff that I am not worried about the pinion bearings. If you are confused about how it looks if you draw a line from the tcase out put through the shaft to the pinion it looks like a frown. Can anyone explain why this worked?
    Ira
