"gotta have 33's"
Discussion in 'OffRoad Design' started by 77K5Blazer, Apr 2, 2001.
  1. 77K5Blazer
    77K5Blazer 1/2 ton status
    Mar 11, 2001
    255
    Hood River, Oregon
    \"gotta have 33\'s\"
    Alright, I want 33's, BAD! I can't afford the gas mileage, on anything above that, or below that, for that matter, but I gotta have them...so? Will they clear STOCK? I want 33x12.5's not skinny pizza cutters, and in the BFG AT flavor. They will not see overly abusive wheelin', but it will be done quite a bit this summer and in months to come. I was told that you have a 2 inch lift that is something other that blocks. How much would it cost to replace my front leaf packs with arched leaves that have 2 inches of lift? I will block the rear, or add-a-leaf if possible. I wanna run 15x8 eagle 589's. So, what can you do for me, and how much will it cost? I am on a BUDGET!
    1977 Blazer w/ 350 GM crate motor
    44 front/ 12-bolt rear, gear driven NP205
    31x10.50r15 BFG All-terrain- Larger on the way!
  2. Hathaway
    Hathaway 1/2 ton status
    Jan 2, 2001
    295
    Missoula Montana
    Re: \"gotta have 33\'s\"
    You should really try their web site. www.offroaddesign.com They have a shackle reversale kit that can get you 2.5" (I think its 2.5 anyway) in the rear. And I think they also sell springs that can get the lift you need in the front. But the Shackle reversal is more expensive than blocks. So if your looking for the cheap route that may not be the best bet. But check the website. Most of the stuff you asked can be found on there.
    Dan, '86 K5, 5.0L v8, NP208, TH700R4, open 10bolts front and rear, 3.43gearing, K&N filter, 31x10.50R15 Trailhandlers
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Some can fit them with a stock suspension but if you use it for Off-road you will probably rub the fenders.... Put them on and see if they will rub. If so, you may want to go with a 2.5" lift or so...
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  4. Slim_Ruthless
    Slim_Ruthless 1/2 ton status
    Feb 20, 2001
    119
    Sydney , Australia
    I have 33x12.5x15's on 15x10's . No lift in the front & Add-a-leaf in the rear . It scrubbed so I followed the handy info on the Good Ol' How to Fender Trim in the TECHNICAL SECTION on this site . They used a SAWZ-ALL but I didnt have one so I used a 4 " grinder ( I am now officially an artist with a grinder ) I will now have to get the gap covered with a little help from the Local Smash Repairer . I have tested it & there is no scrubbing any where .
    [​IMG] <A target="_blank" HREF=http://baulko.coloradok5.com>http://baulko.coloradok5.com</A>
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have 33x12.5x16 with no lift and i dont rub the key is the offset do not get any offset and you will be fine
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
