gov-bomb woes
Discussion in 'The Garage' started by thezentree, Jan 10, 2005.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    my 10 bolt rear gov-bomb keeps locking up solid in sharp left turns on dry pavement and it's really starting to piss me off. anyway, is there anything i can do to that POS so it'll quit that crap? the gear lube hasn't been changed in who knows how long, yall think it's worth smelling gear oil to change it?
    (secretly i hope that it grenedes so i have an excuse to swap in a 14 bolt :rotfl: )
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Changing the fluid and adding the gear lube additive should help it. I would try and blow it up and swap in a 14 bolt:xmas:
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its going to blow up , mine was just like a locker , worked great on trail ........then BOOOOOM :D
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    yeah, its about to go out. if it going out anyway you might as well try to help it along and have fun blowing it up in the process. repeated power braking should do it:D
  5. dyeager535
    26,977
    I believe if you break the centrifugal weight (flyweight IIRC) that will solve your problem.
    Way back when I was brand new to these trucks, mine was staying locked up as well, buddy got in there, pried on the flyweight, broke it, and never had it lock up around corners again.
