gov loc disaster avoidance
Discussion in 'The Garage' started by 76zimmer, Jun 5, 2006.
  1. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Got the 10 bolt gov lock in the back of the Burb, and was wondering how to take things apart and avoid the Kaboom of the gov lock. It has stopped working, so I figured I might as well take out the grenade if possible before it blows. What can you take out, and what needs to be left in? And its a 95
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    throw in a new carrier. New bearings and recheck/adjust backlash as needed.
  3. dyeager535
    26,982
    191
    If it doesn't work, then there is nothing you need to take out to avoid a problem. The thing breaks because of the locking/unlocking, if it never locks, any further problems will be normal wear and tear, as long as no pieces are floating around in there.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I'd remove the little weight locking thingy in there, to prevent it from locking altogether, it may still be locking, but the clutches might be slipping too much which is why you think it isn't working.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I have the ability to break 10 bolt carriers in about as much time as it takes to read this post regardless of tire size. If it were mine i would put an aftermarket differential in there. You get the benefit of a limited-slip or locker as well as something to bolt your ring gear to.
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Yeah, he might as well just go throw in a Dana 60 and a 14BFF under there while he's at it huh?:rolleyes:
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Yep it works for me:D
    Ira
  8. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Well, I don't need to go that far, on this truck yet. Its a DD (when I can afford the gas). I just want to prevent an explosion. My brother had that happen in his 14bsf, and I just pulled the cover on my project 14bff, and it looks like some stuff got loose in there as well. A few knicks in the gears, but nothing serious. Thanks for the tips, maybe a Trutrac?
  9. 4xcrazy
    Oct 31, 2003
    9,472
    5
    And this is all i was trying to give advise for, i would imagine, that if you HAD the money for a conversion like that, you wouldn't even had posted up a question asking how to TRY to extend the life of a Gov-Loc'd 10 bolt.
