gov lock how too???
Discussion in 'The Garage' started by buhlandy, Apr 28, 2007.
  1. buhlandy
    buhlandy Registered Member
    Dec 2, 2006
    44
    tn
    hey um jw how can a gov lock be tested its for a 14ff.... and can it b rebuilt if the clutches are worn???? and do you use additive with a gov lock
  2. dyeager535
    26,977
    Gov-lock test: jack rear end off the ground, rotate one tire, note direction of other. Opposite/no revolution of opposite tire, it's not locked up. Good.
    Next test, rotate same tire QUICKLY by hand and the other axle should lock in, and you'll know it.
    As to lube, I'm too lazy to go search, but I *think* GM spec's GL-5, which already has some friction modifiers in it AFAIK. None called for that I've seen in manuals. It would NOT be surprising if the lube specs have changed since the introduction of the gov-lock.
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Dealer sells posi-unit lube.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I thought posi lube was for cone type diffs ?
    All the Gov Loc's I have seen have had metal friction discs , and worked fine with just regular ol lube ( until they let go LOL ) .
  5. dyeager535
    26,977
    Not just cone type, Eaton (and others) make/GM uses a flat clutch style as well. Anything spring loaded. Since the gov-lock isn't "preloaded" like the spring type posi-diffs (which bind the axles together at all times) it doesn't need anything to prevent clutch chatter when you corner.
