gov lock maybe?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by option#9, Oct 22, 2003.
  1. option#9
    option#9 Registered Member
    Feb 17, 2003
    11
    Poulsbo, WA
    This could be a long one; not sure yet.
    Couple of weeks ago I was in my driveway going around a corner and it felt like the rear end was locked up, not slipping a bit. I got out checked the fluid( it was thick as gum) backed up a little bit pulled forward a couple of times and it seemed to unlock. I was thinking that I should really pull the cover and take a look but we were moving, getting married and going on a honeymoon, it slipped my mind. Today I'm driving home from work and notice a whining sound seemed to be coming from the rear end. I stopped by the auto parts store to pick up some spark plugs on my way and the whine wasn't as loud when I got back in. I decided it was definatly time to take the cover off and take a look when I got home. But just before I got there I was driving up a hill from a stop and 90 degree left, and the rear end made some aufull clunking sounds and then stopped. I was only 1/4 mile from my house so I kept going and parked it. I removed the cover finally to find dripping water and sludge, kind of light brown, no metal shavings. Are you supposed to be able to scrape it out with a screwdriver?
    I'm rambling, fuel injection went south on the Honda day before yesterday; don't really know how I'll get to work tomorrow so beer sounded like the way to go.
    I don't think my profile has the specs on my rear, pretty sure it's stock with the gov lock behind a built 454 and turbo 350. I'm new to K5's but that doesn't seem like a good combo to me. I was planning to replace the rear just not so soon, guess some suggestions would be great.
    That was a little long.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I don't think the gov lok is your problem, it's the water and sludge. Probably ruined the rearend. /forums/images/graemlins/frown.gif
  3. option#9
    Feb 17, 2003
    11
    Poulsbo, WA
    That's what I was thinking, I guy can dream though can't he?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Put good oil in and take it easy on her.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    if it is a 14bolt ff you can add a detroit locker for aroud 300.00
  6. option#9
    Feb 17, 2003
    11
    Poulsbo, WA
    Anyone have good ideas for flushing out the grease that's in there? And how about some recomendations for replacement fluid? It's a stock 10 bolt with the factory locker.
    The Haynes manual calls for limited slip additive added to the specified lubricant which I am assuming is the 80w GL5 specified for the US diff. When they say limited slip they are talking about the factory locker aren't they?
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]There is a big difference between a locker and limited slip. a limied slip has disks like clutch plates that will slip as needed to provide traction as needed, A locker has gears that will lock both axles to the differential so both wheels provide traction when needed.A locker has no plates to slip.No really a technical description,but hpoe this will help....
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I had a gov-loc....lock-up on me....and do the same thing..
    clunk...after a couple turns...
    When I took off my cover...I had teeth from the gov-loc itself...sitting in the bottom of the housing..they were ground-up by the ring & pinion.. /forums/images/graemlins/eek.gif
    I would jack-it up..with cover off..move the axle shafts and yoke...and see if you hear or see anything..
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    govlock is a limited slip/locker style locker, so it has clutches and gears/counterweights.. mine went bye bye with a 350...so good luck making it last behind a bbc
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A gov loc is an interesting combo between locker and L/S unit. It is neither one nor the other.
  11. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]Tim,Are these any good (gov-lok)I was told that they are not very strong?
  12. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Sounds like it is going to be time for a new axle really. If you need to get by cheap there should be someone on here in the seattle/pullyup area that has a stock axle for you cheap (or try the Snort4x4 forums too).
    I would take a close look at how you want to use the truck. The Semi Floater 14 bolt would be a good choice for a stronger axle if you are mainly doing light wheeling/street driving. The Full Floater 14 Bolt would be the best for big tires and heavy duty use.
    What gear ratio do you have right now? I have a 3.40 ratio 12 bolt that would bolt right in just sitting around collecting dust...
  13. option#9
    Feb 17, 2003
    11
    Poulsbo, WA
    Not sure what the ratio is, still looking for the stamps. I think I'm just going to try and count though. I got a closer look at it today after work, the whole thing is slopping around in the housing. I can wobble the left wheel and watch the ring wobble with it.
    There sure are a lot of funky parts and springs in that locker.
    I have 38's on it right now but moving down to 35's untill I can get it regeared and new suspension lift. Sombody had thrown a 3" body on it to clear the 38's, I took it off a little while back and trimmed the fenders so they would just barely fit and am in the market for some 35's as soon as I can come up with the money.
    A 3.40 would get torn up pretty fast trying to push 38's wouldn't it?
    I just saw some 35 micky thompsons with 80% on Ebay for $400 in Snohomish if anyone is looking. I think they are going for under $250 right now. If I only had the cash.
    It looks like the ratio is 3.07, couldn't get much worse, specially with 38's. In my own defense I've only had the truck a few months and hope I would be a little wiser when putting that much rubber on something.
  14. option#9
    Feb 17, 2003
    11
    Poulsbo, WA
    Suggestions please.
    I'm sure this has been asked way too many times to count, I did some searches and read some stuff but am going to ask anyway.
    I can't decide what to do. I have the stock 12 bolt(I think I said it was a 10 before but I just counted) that needs to be replaced. I would like to upgrade now, since it needs to be done but I'm a little short on cash. I don't have a choice in regearing the front because I'm not sticking with the 3.07's, my front driveshaft is bad anyway and sitting in the back of the truck so that's not a big deal right now.
    What should I get for the rear? I can't move up to 8 lugs, can't afford new rims.
    454, th350 on 38's
  15. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] They totally suck in a 10bolt. Extremely weak which is why they got the nick name gov-bomb. BUT..... in a 14bFF they work better and are much stronger. I have one in my 14BFF and it works OK. I had one in my old 10 bolt too. I have never had any problems with breakage but both take a lot of power and wheel spin to engage but when they do lock they work great. I never have problems going strait but If I need posi going through a soggy turn. half of the time it won't lock. Sometimes it will "one leg" on me when I spin a dohnut. I am thinking of going with an aftermarket locker/limited slip besides the detroit locker if any are available when I get 4.88 gears.
