Gov-Lock owners
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Oct 1, 2001.
  1. dyeager535
    26,977
    Happened to be checking out one of my favorite reference materials(about limited slip, posi, you know : ) and ran across the gov-lock (eaton positive locking differential) section. Never seen this in print anywhere else, but you are NOT supposed to run limited slip diff additive in the gov lock. Same goes for the (3/4ton?) Gov-Lock.
    It lists 5 different types of "limited slip diffs" installed in trucks. the one that I thought was Auburn (cone clutches) is atually a Borg Warner unit, and one LS diff is Eaton, one Chevy, and one a "power-lok" whoever makes that.
    Just thought I'd pass that info on! : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think the "Power-Lok" was made by Spicer.
  3. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    My shop manual agrees that no addative is needed in the Gov-Lok. I've been running GL-5 in a 3/4 ton Gov-Lok for 160,000 miles with no problems.
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Just don't beleive everything you read !
  5. dyeager535
    26,977
    Are you saying that the GM service manual is wrong? Not that it hasn't happened before (1985 Monte Carlo SS's didn't get 800CFM Q-jets for example) But with something like 5 or 6 different axles listed for the the trucks, made by at least two different manufacturers, you don't think the number of "Posi Units" used could equal that? Or you think that GM is wrong with the additive?
    At least I learned something from that manual...didn't realize the gov-lock (is supposed) to unlock at over approx. 20MPH. Max tire speed differential at low speeds before it "locks" is 100RPM.
    Dorian
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    just run 4096 pennzoil in everything. has the additive in it i believe
  7. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    OOPS! to late for me!
    Surfing is Life...
  8. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    I think this needs more input, back to top [​IMG]
    Jeff427
    <a target="_blank" href=http://lyonsdesign.bizhosting.com>Lyons Design Web Site</a>
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Hey Dorian,
    I used to have a 2wd 88 GMC shortbox and it had 3.42's and the Gov-lock. If I wanted to roast em up the truck would start out all sideways [​IMG] and all of a sudden it would revert to one wheel peel. So I guess the Gov-lock in that truck was working correctly...[​IMG]
    Rene
