GOV-lock to Detroit Locker upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by domator, Oct 20, 2002.
  1. domator
    domator Registered Member
    Feb 20, 2001
    12
    Poland, Europe
    I have CUCV with GM Corp. 10 bolt rear axle. This axle has gov-lock. I would like to change it for DetroitLocker. Am I going to have any problems with it ? I mean - should I find open differential instead of gov-locked for that installation ?
    Piotr
    1986 CUCV 6.2 NA D 35" BFG
  2. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    You need a open not gov-lock to install the detroit. I don't think you can install the detroit in place of gov-lock.
  3. domator
    Feb 20, 2001
    12
    Poland, Europe
    Why? I think Detroit comes with new carrier and whole differential. I think from my old axle I have to leave just axle shafts (case of course), bearings and that's all. Am I wrong ??
    Piotr
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The 10-bolt rear axles are the weakest axle option out there. I personally would be worried about it breaking WITHOUT a locker. Adding a detroit is a bad idea, in my opinion.
    Option 1: Wheel it gingerly until it breaks (it will) and be glad you didn't spend any money on it. Then, get a stronger axle.
    Option 2: Ditch the axle now and install a stronger axle.
    Yes, this opens up a can of worms such as not wanting to buy 8-lug wheels ($50 each, not a huge concern unless you want pretty wheels.) Also, have to use adaptor ujoint OR buy new driveshafts. It's worth it. Don't invest mnoney in 1/2 ton axles as you will regret it.
    -- Mike
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Just noticed you are in Poland. I have no ideas about how available bigger axles are.
    If they are not available, be forewarned that your rear axle is very much so your weak link. Adding a locker will only decrease it's TTE (time to explode.)
    -- Mike
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I disagree, the the weekest point of the 10B is the gov-loc. If he replaces it w/ an aftermarket case it will be stronger. He still may break a shaft w/ 35s but the Detroit will be fine.
  7. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    joker, that is only for a 14B, w/ a 10B and just about every other axle, except a 2 1/2 ton Rockwell, the whole case is replaced.
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Dominator, you need to decide now if you are going to keep the 35s and 1/2 ton parts. If you will be staying w/ the 35" tires I would recomend the Detroit and maybe some new axle shafts. If you plan on going bigger I would not put any money into the 10B axle, you would be better off using a stronger assembly.
  9. joker89blazer
    Nov 21, 2001
    130
    Looks like your right. It's the 14 bolt that does not interchange. Sorry about that. Do you think the detroit would handle ok on ice and snow ?
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    It will work great in snow. Ice will be a problem, though. When the locker locks, it causes the tires to turn at the same speed, possibly causing you to loose control. You will definately have to be more careful.
  11. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The gov-lock on all axles is replaced by the detroit locker except the 14bFF because it uses the existing carrier (that's why it's cheaper for the 14bFF /forums/images/graemlins/smile.gif)so yes you can replace it and you will get better/stronger performance, and if you only run 35"tires you should be fine.
