gov lock
Discussion in 'The Garage' started by schmuck, Feb 21, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    i would like some info i know they suck but why, what is so bad about them, are there any good things about them, is there anything imparticular you can do to make them better and dont say 14ff axle im still running 10s and i will not change them until i break them and even then ill probably go to 12s, please dont get into that i just want to know about the gov locs ive been running mine since i got the truck 2 years ago and have not had any problems i wheel about once a month and drive the truck everyday and when i wheel i whell as hard as my mostly stock truck alows[sp?]the only problem ive had is getting my fingers in there to take the clips out and put them back in other than that no complaints.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I blew mine up driving on the street. It wasn't too long after I bought the truck, and had been wheelin' it damn near every week. Had just changed the diff. gear oil, too. There is an additive, but I've heard yay and nay on whether or not to use it. The Gov Loc will fail. Do a search, there are some nice pics of some grenaded Gov Loc's out there.
    John
  3. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    I have the exact same ?'s about these 'notorious' gov locks. I have searched and I see that no one likes them, and I have seen the pics of destruction.
    Gov locks are the same as G80, right? Eaton limited slip, right?
    I have one in my pick up (2wd), and I had 50 series tires and got rubber all through 1st, 2nd and got scratches in all other gears. Gov lock is still doing fine. I know that is not the same as rock climbing with 38's, but within its limits, I say it is good.
    Now the question becomes, what are the limits? I think it should be ok up to 33" tires. It is good for daily driving with some off road use. I dont think I would use it in a situation where only one wheel has contact.
    Just my .02. (and it is probably only worth .01 /forums/images/graemlins/blush.gif !)
    I would like to hear others ideas and experiences also. Espically what size tires and what type of wheelin was involved.
    thanks
  4. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    I blew up my GM Gov Lock. Replaced it with an Eaton Limited Slip. Much better design. Less moving parts as far as I can see and does a good job of grabbing. (12bolt rear) I love it. Running 33s now but moving up to 35s soon. Also going to put an Eaton Limited Slip in the front D44.
    I follow the big fuly locked trucks in my club around just fine and even they said that it seems to work much better than my old GM govlock did. Don't want to go full time lockers till I can trailer the rig.
    I'm still in the learning stage of wheeling and truck building but so far I'm happy with my Eaton...
  5. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I was/still am running 31" MT's. I will quailify that when I bought the truck, the rear end had a "whine" to it, which the owner said was normal w/ posi. Also, the wheeling I had been doing had a lot of skinny pedal involved. I believe a lot of the other Gov Loc failure experiences here were with close to stock trucks, and smallish tires. Wait for others to chime in with their stories of hate and discontent of the Gov Loc.
    John
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    My Sub came to me with a blown up 14b Gov-Loc. Time being what I didn't have b4 the trip to the 1000, I put an open in it. When gainfully employed again it'll get a Detroit.
    I think the Gov Loc is an excellent idea.
    I think the execution of the idea sucks. All of the lock-up load is on 1-2 tiny little gear teeth. It's no wonder they strip off. The wqorst thing you can do to a Gov Loc is let a tire spin. When it finally does engage while a tire is spinning, the inertia of the system is too much for those little teeth.
  7. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    IF you've ever looked at how the gov loc functions.. you wouldn't be asking these questions.
    Like previously said, great idea, typical crappy GM execution. There are very small parts that are required to withstand very large loads, They'll only handle them for so long.
    Given the right circumstances, I personally think I could destroy a brand new one in less than a day. We're talking some serious abuse but very possible.
  8. 90K5Blazer
    90K5Blazer Registered Member
    Jun 10, 2002
    48
    Dayton, Ohio
    I drove my truck stock for 2 years. Wheeled it 3 times, in the mud, no rocks, and the mud really wasn't that deep anyway. 168,000 miles took off from a red light (normal takeoff) got to 25mph and heard a huge boom. The rear-end grenaded. If you call any transmission/differential shop, and tell them you have a gov-loc, they will ask if it has "grenaded" yet. It is that common. If you are planning on running anything bigger than stock tires, get rid of the gov-loc or change diffs. MOO=(my own opinion) /forums/images/graemlins/ears.gif
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my gov loc went boom too, while drive on the street i made a tight turn and recoreced the turn and heard a wa-bam, didnt take much notice to it untill i drove it around and made turns, tires chirping when i turned, uh oh its locked, so i get the great idea to violently back up, that didnt unlock it, then i took it home and went to my dad for advice so we drove it around and it went WA BAM, and the rear of the truck souned like someone rear ended me bad, but no it was the diff, i limped it home, took off the cover, it cracked in half in one spot, i got lucky, found a 12 bolt open diff with 3.08 gears for free, installed it, problem solved /forums/images/graemlins/thumb.gif. the 10 bolt serves as my mail box post now /forums/images/graemlins/rotfl.gif im not lyeing i will get some pics one of these days.
  10. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I have a Gov Loc and LOVE it, however mine is in a 14B FF, it works really well and when it locks it's locked (it chirps the tires turning around on the street when it's locked). I run 36" TSL SX's and wheel my truck pretty dame hard, and it had held up fine. That is my experiance. Has anyone else had any big problems with the 14B ones? Later
    -fLeXy K20
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    In my opinion The problem with Guv locks is as others stated above. Too much stress on small parts.
    Usually what happens is a small pieces of metal break off and circulate around the diff with the fluid till it gets wedged between a moving part. Every thing somes to a stop and the rear end goes BOOM! They usually give no warning before they blow because they still work fine and dont make much noise even with broken parts inside.
  12. hoosierk3500
    hoosierk3500 Registered Member
    Jun 5, 2001
    44
    Huntington,Indiana
    I've had good luck with mine,but it is in a stock /forums/images/graemlins/burb.gif,that doesn't get wheeled that hard.Have had it lock up and not want to unlock though.If mine goes boom it will just be a good excuse to put a 14ff in and trash the sf.Jason.84k3500 /forums/images/graemlins/truck.gif85k2500 /forums/images/graemlins/burb.gif
  13. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    my friend calls it the gay lock, because my friend calls it that. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  14. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I ragged mine hard and had no problems on 31" MT's in a 6,500 lb. truck. If you have a tire in the air, don't floor the gas, let off and let the thing lock up and then move on. It lasts for some, it pukes for others, hope you have it's good side.
  15. schmuck
    Nov 11, 2002
    523
    well no problems yet i was just wondering what to look for like i said if it aint broke dont fix it i rarely wheel far from home and always use the buddie system so i should be ok fo now
  16. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    HOW CAN I TELL IF I HAVE ONE?I HAVE A 86 K2500 GMC SUBURBAN WITH A 14 BOLT REAR.THE DETROIT GEARLESS LOCKER SUCKS TOO.MY BUDDY JUST BLEW HIS UP ON THE STREET AND IT WAS ONLY 6 MONTHS OLD.GUESS THATS WHY THEY STOPPED SELLING THEM.
  17. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    is it marked on the housing anywhere?
  18. schmuck
    Nov 11, 2002
    523
    not that i know of you probably need to open up the pumkin
  19. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Open the glowbox nd check to see if "G80" is on the codes. That is the code for a gov lock.
