Gov-lok question
Discussion in 'The Garage' started by bajaviking, Oct 10, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I bought a second blazer a few weeks ago and just found that is has the dreaded gov-lok in it. I am not planning on putting anything bigger than 33's on this truck and since it will be mostly a daily driver it will probably be OK, my other K5 I am planning on turning into something a little more hard core. Anyway, how do I service the gov-lok, does it use additives, should I just use regular gear oil. Any usefull info and tips on how to keep this thing working would be appreciated. And yes I know it sucks and that I should throw it away but until I get something better I want to get the best out of it. /forums/images/graemlins/ears.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well ill tell ya what...i had a 10 bolt govlocked with 33s and it worked fine apparently for the first 138k that the original owner had the truck, less than 4k with me driving it...so keep your driving easy and since its a clutch pack limited slip/locker, you should get some limited slip additive or friction modifier..
  3. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I always ran gear oil with limited slip additive in it. I didn't blow mine up until one episode of real heavy bogging with 33" swamper radials. Worked pretty good before that.
