Gov-lok rear & detroit front? Will it work?
Discussion in 'The Garage' started by hidesertwheelin, Jun 3, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I have a 10-botl front axle with a detroit locker. I bought a 14-bolt that came with a gov-lok. Will this work? Is there a chance of blowing the front axle when the rear enganges? I was told it might cause the front to blow.
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Doesn't matter what you have in the rear, a locked front 10-bolt might grenade on you. That sems to be the opinion round here. That said, I know a few guys who run locked front 10-bolts hard and have never had a problem. If you wheel with your brain and not with your right foot, that 10 bolt should last. Gov-locks, often referred to here as Gov-bombs, are more of a liability. Get rid of the Gov-lock when you can and swap in a Detroit.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I have wheeled mine pretty good with this type of setup, i have a Loc-Rite in the front of mine though, ran for awhile with a welder carrier in the front as well,no problems, except with steering.
    I am very happy with my current setup, but would definately like a Detroit in the rear diff.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I've always heard that a 14's gov is much stronger in comparison to a 10's... and that they are usually up to the task. The DL in the 10 will probably be fine, especially if your not running very large tires.. and like mentioned, you go easy on the skinny pedal.
  5. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I think they are referring to using a locked front diff, with a Gov-Loc'd rear 14bff,,, can be done, thats the way i'm runnin, wish i had the detroit though,
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have an ARB up front and a Gov lock in the rear 14ff. For rock crawling the rear is worthless.
    The front hooks up so well that the tires never spin enough in the rear for the Gov loc to work.
    Detroit is in the near future.................
