Govener
Discussion in 'The Garage' started by 84gmcjimmy, Mar 30, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, I was wondering if a govener is something that only lets you go up to a certain rpm? If it is, is it worth getting for off-roading so you don't stall? Thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you mean for a tranny? it tell the tranny who fast the truck is moving to alow it to shift at the correct spot.
    the governer and the tv cable on the 700r4 have to work together.
    on the th350 the governer and the vacuum from the motor tells it when to shift /forums/images/graemlins/waytogo.gif
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    My dad said something about it a few months ago, and it must be soemthing different then what your talking about because I have a SM465, no auto for me. I don't really no what it is. Sorry If I've confused.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    If I'm thinkin along the same lines as what you're askin, a govenor limits the rpms of the motor so you can't over (not under) rev the motor. If that's not what you're shootin at then please do ignore what all I had to say. /forums/images/graemlins/thumb.gif Good luck to ya in the future.
    Allan
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Allan
    Thank goodness for CK5, thats exactly what I meant, im kinda tired tonight so I couldn't think of what it does. But yes, thats what I meant, thanks Allan. Anyone no anything about these? Good/bad.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah, they're called Rev-Limiters /forums/images/graemlins/thumb.gif
  7. justhorsinaround
    Sep 16, 2003
    6,798
    If'n I remember correctly usually they limit the amount of airflow into the motor. The one that comes first to mind is the stock turbo Corvair. I own one so that's why. /forums/images/graemlins/whistling.gif They used a carb that would only flow so much air into the motor thus not allowin the motor to over rev. Other ways I think are chokeing the motor down with the butterfly. Anyways, that's just shootin from the hip type stuff. Good luck to ya in the future.
    Allan
