Govenor cover on the side of 700 R4. How is it held in
Discussion in 'The Garage' started by cybrfire, Feb 9, 2004.
  1. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Or more specifically how do you remove it?
    Is it a C shaped clip that holds it in?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it is just pressed in. sometimes there is a clip like on a 350 but never seen one one a 700r4. just stick a screwdriver in there and pry it out. /forums/images/graemlins/waytogo.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Let's just clear this up...you're talking about the governor and not the servo, correct?
    The servo is held in with an outer clip (similar to that holding your locking hubs inside your hub).
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    It's a round cover about 3" diameter. I got the clip out of it but stuck. IF that isn't the govenor what is? Transmission shop I talked to said that is the govenor and to check and see if it is stripped or the weights are stuck. Something like weights in the distributor the fling out as it spins?? /forums/images/graemlins/dunno.gif
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the cover in this pic is the governer. it is on the driver side toward the rear.
    the red cover in this pic is the servo. it has a snap ring holding it on it is on the pass side
  6. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Well, sun of a ______ I guess I was going after the wrong cover. /forums/images/graemlins/dunno.gif
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    This is what a stripped govner looks like.
    Looking like this it prevents the trans from shifting out of 1st.
