GP Light dim when warm
Discussion in '1982-Present GM Diesel' started by alec78, Mar 10, 2003.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I did a search for this but didn't find anything. Simply, the dash GP light is on but VERY dim. I only see it after the sun sets. What does this mean?
    Also I have seen posts about being careful when changing glow plugs. I've read posts about the tips breaking off but is there something else I should be watching out for?
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine is the same way, has been that way for quite some time its on all the time but can only see it at night. I havent worried too much about it because its not closing the contacts in the gp relay. I also believe I have a ground issue with the dash.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Does it start OK when its cold. If it does, then dont waste your time and money replacing glow plugs, dont fix whats not broken.
  4. alec78
    Aug 5, 2002
    358
    Washington
    Starts so-so...Replacing GPs in a couple of weeks. Thank to both of you! /forums/images/graemlins/thumb.gif
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    What year is diesel? (fill out your profile). Are you using an AC delco controller? My previous (non-AC) controller was doing some flaky things before I ditched it.
  6. alec78
    Aug 5, 2002
    358
    Washington
    Sorry about the profile, I'll get that fixed. I don't know what the controller is, I just bought the /forums/images/graemlins/k5.gif a month ago. I am going to test gp system this weekend (currently looking for the proceedure (sp)). I may toss it just to be sure.
  7. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    My K30 does this too plus the gauges show a little strange sometimes.When I turn everything off it goes off and when I put on something like the parking lights the gp light dims a little /forums/images/graemlins/confused.gif
  8. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I found the problem with my K-30 there were no ground wire from the battery to the body.Now everything works like it should. /forums/images/graemlins/thumb.gif
