GPS Speedometer..
Discussion in 'The Garage' started by SS66, Jun 2, 2006.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Does anyone out there know of a "GPS speedometer" unit that can be had for under $100?? They are often used in boats but the only ones I found were several hundred
    THanks
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Why not just get a GPS and a suction mount, then you can take it with you when you leave the truck?
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I have an ipaq pda... i use that...
    how come you dont get yours fixed? manual tranny? they can be fixed too.. I just havent bothered... :haha:
    it is SOOO ACCURATE TOO!!!! :wink1:
    nice thing about the pda is you can do so much more with it.....
    you can read more of my setup here
    http://www.pavementsucks.com/forums/viewtopic.php?topic=70670&highlight=gps
    for speedo I use....
    you can change all the buttons on the bottom... 40/50/60.. all those can be changed.. you click on which one you want to use and when you go over that speed it will turn red.... the background can also be white and numbers black.....other cool thing is the lil tabs.. elevation... speed at times.... also you can reset the counters.... use the software and it will keep track of your miles.. all of them..then you can calculate your mileage!!!!!!
    I saw this but havent tried it yet
    http://www.pocketgear.com/software_detail.asp?id=22142
