Grade 5 vs Grade 8
Discussion in 'The Garage' started by Muddytazz, Mar 12, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I found a good page on the differences and shear strength of each...good reading material /forums/images/graemlins/thumb.gif
    Bolt Grades
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Thanks, that's a good one. /forums/images/graemlins/thumb.gif
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Good Article! /forums/images/graemlins/thumb.gif
    Thanks,
    John
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Good Info!! /forums/images/graemlins/thumb.gif
    Thanks for passing it along! /forums/images/graemlins/thumb.gif
  5. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Very nice find, thanks for sharing the info.
  6. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    That was a good read!
  7. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    I really had no clue about any of that.
    Thank you for posting the great info. I'd love more articles like this one.
    thanks again.
  8. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Now I know a lot more about fastners that I never knew /forums/images/graemlins/thumb.gif Thanks for posting that up
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    this is why when i replace a bolt on my rig... its ALWAYS grade 8 or stainless. /forums/images/graemlins/grin.gif
    j
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Uh, Most stainless fasteners are Grade 2 equivalent, some are what I call Grade Zero. Use them only in cosmetic applications, never in load bearing applications unless the bolt is so rediculously huge that this won't matter.
  11. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I would never always use grade 8. Most of the stuff on your motor is grade 5 anyway. Some items are ment to have some flex or distortion. Ask Steven watson what they send out with there lifts and other items. Some things may very but grade 8 can be over kill sometimes and could cause problems. Stainless is not only grade 2. ARP makes complete engine bolt kits that are stainless. There are different grades there too just not always marked on the head of the bolt. I have been selling fastners for 8 years glad to see the interest. I tell people that junk everyday /forums/images/graemlins/smirk.gif
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I generically consider all hex headed stainless fasteners to be Grade Zero unless I know where they came from and then I consider them to be no better than Grade 2. That keeps me out of trouble.
    Even ARP has had trouble with high strength stainless fasteners. They pulled their stainless head bolt & head stud kits off the market a while back because of yielding below the specified torque values. Don't know if they have re-introduced them or not.
    There is a 'stainless' alloy available that does make good high strength fasteners. It's called Carpenter 20. If you find some of that stuff cheap would you let me know ?
    As to the linked author's contention that G8 is not too brittle and can be used in place of G5 in applications where ductility is required. Sorry, Don't buy that. I've seen G8's snap in applications where the previous G5 merely bent. Yes, it got bent all to hell, but it was still in there unlike the G8 in one particular instance which popped it's head off and disappeared.
    If I need more strength than a G5 I go to MS spec hardware or use HoloKrome SHCS's, depending on application.
