grade 8 good enough for the motor mount bracket...........
Discussion in 'The Garage' started by down4thakrown, Jun 8, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    that bolts to the sid of the block with the 3 bolts?
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    More than enough.
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    we had this same question about an engineering project we just finished for school... so i went looking for bolt specs and found this...
    http://www.rockcrawler.com/techreports/fasteners/index.asp
    strength in tension and shear for common bolt sizes... should answer any question about "is this bolt strong enough" for you
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It doesn't really get better then grade 8 unless you are talking about expensive aircraft bolts or specialty bolts that are expensive also.
    Harley
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I just put in a motor, grade 5 is what came stock on my 350 although i had some grade 8 lying around so i used those just because the heads on the grade 5 ones were bad. if you have grade 8 bolts your fine, but really from the factory grade 5 was all they needed.
  6. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i have heard that grade 8 is the strongest but can break a little easyer then grade 5 from being too rigid.
    is this true?
  7. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Ive heard something similar. Grade 5 will bend before it brakes, grade 8 has no give/bend so it just breaks. It takes more for a grade 8 to break than it does 5 tho AFAIK.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    That's what I was gonna say, more than enough with grade 8
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    G8 is stronger than G5 in every way. G5 will fail completely in both shear and tensile stress before G8 will even deform. The "old wives tail" about G5 being "better because it will bend" is simply not correct, but possibly due to the fact that G8 often does not show signs of stress before failing where you can often see bent or deformed G5s before breaking. But the simple fact is that if you break a G8, the G5 would have been LONG gone...
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I personally have bent Grade 8 bolts and seen other people bend them also. Like Baddog mentioned. They take alot more load without breaking but when they break they do tend to shear off or snap.
    Grade 5's usually bend/deform more before they break but Grade 8's will bend/deform also depending on the circumstance. They just don't bend/deform as far before they break off.
    Harley
  11. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    lol, i wonder how long that "gr 5 is better" myth is going to survive. Seems never ending... every time i see someone say that on a forum i correct them, but new people keep on bringing it up. Maybe there should be a pasty about this in the garage forum... lol! :grin:
    j
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I was wondering that myself.
  13. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    :blush: lol i shouldent have said anthing :cool1:
    the only reason i said this, is becasue the last time i made a similar post to this one someone told me grade 5 was better.
  14. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    actually, it was a good thing that you did... the last thing we need is some poor noobie guy ending up dead because he "heard" that gr 5 was better and so he used it on all his suspension and steering parts. If you're not an engineer and can't run the numbers on a fastener, its a pretty good rule to always use gr 8 for auto applications if its going to be subjected to much load at all. Sometimes it will be overkill... but overkill in this case isn't going to get you killed like under-spec'ing something might. :)
    j
