grand finale on 14bff question...
Discussion in 'The Garage' started by XHitman396, Jul 10, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    Well i just got a 14bff from a fellow member, and all went well, i planned on leisurely swapping it in the k5 as i could, no rush, blah, blah live happily ever after.. all hell broke loose, and now im under time constraints and my backup vehicle i was driving until the blazer is fixed has blown up and i could go on. So i have never done anything with rear-ends before, so ive got some questions i want to ask: (ill just tell you what im doing though it may not be a question, so just jump in with your $.02 if you would do something different)
    1) Brakes. It's been sitting for a while, and i open up the brakes and everything is together quite nicely, spider webs and rust, but together. I want to get everything done before i put it in the truck. So i was just going to replace the shoes and cylinders for the hell of it and have the drums turned on a lathe. The brake lines on it are kinda mangled, will the ones from my 10 bolt match up exactly or should i replace them with new ones? They look a lot like the 10 brakes, just bigger. Will there be anything different from the 10 bolt? How about the parking brake, will the hardware and stuff from the 10 bolt match up??
    2) Seals, gaskets, etc. So i found out the hard way (and ignorantly) a full floating axle has a lot more to it than a sf. while i have it apart should i replace the seals on each end? What about the bearings, is it easy to tell good ones from bad ones?
    3) Specifications. I looked at the 14 bolt bible from Pirate, but couldnt find the spec's one how tight to torque down the spindle nuts. Anyone know??
    I forgot to mention, as usual, im on a budget.. no really, i have no money to be spending on this thing, and already i spend $35 on two sockets (one for front hub, one for rear), and now the brakes, gaskets, etc. are adding up, but i also want to do this right. Thanks a ton for everyone who has helped me thus far, and will in the future.. Any advice, tips, anything, is appreciated..
    EDIT: and what about U-bolts?? im assuming i will have to get new ones of a different size? will they assemble the same, i saw a diagram that depicted the 14bff having a completely different way of bolting the springs to the axle, and different components. can someone fill me in there?? divorced is sending me the 14bff spring plates this week (actually, for free and he's paying shipping, for no reason. helluva nice guy), but is there anything else i should be tracking down?
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    its best to replace the seals, wheel cylinders, and pads.
    your 10 bolt brake lines will hook up.
    you parking brake cables most likely NOT hook up. i am in the process of figuring out how to make mine work.
    you will have to get 3/4 ton ubolts
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    So the U bolt in my V2500 Suburban will bolt right iinto my 14bff?
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Here is what the spring plates will look like. You will need new u-bolts because the 14 bolt axle tubes are larger diameter than the 10 bolt axle tubes.
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    it will! I went from 14sf to 14ff last summer no problem at all.
