granite hills = fun and carnage
Discussion in 'Plains Region' started by rocko, Jul 28, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    ouch ric... did you drive it home ? was it okay on the highway?
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    highway driving was a little hairy, as you can see from the pic i tightened the u-bolt as tight as i could and just took my time getting back home.
    we made it back, so all is good /forums/images/icons/grin.gif
    now it's time to get to work... /forums/images/icons/smirk.gif
  3. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I did the same thing awhile back. I just drilled the hole a little bigger and picked up some kind off strange aircraft all tread stuff that I used as a stud I still have some and the drill and the tap. You will need to remove the axle and rent a big A$$ drill. Let me know if you want to use what I have. /forums/images/icons/tongue.gif
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    man that hurts...i'll have to post some of the pics of my transfer case crossmember when i get a chance...i spent all day today just getting the frame straight again...as for my crossmember...i think its got little wings and a harp.
  5. BOWTIE
    Dec 28, 2000
    2,018
    well for what little wheeling i did out there /forums/images/icons/frown.gif
    there was carnage.
    sheared the bolts completely off /forums/images/icons/shocked.gif
    anyone have a good method of removing the bolts??? /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  6. BOWTIE
    Dec 28, 2000
    2,018
    thanks alot BR,
    i'm gonna try to remove the bolts and if all goes well prolly use studs instead of the bolts.
    if that doesn't work you'll prolly get a phone call. /forums/images/icons/grin.gif /forums/images/icons/tongue.gif
  7. BOWTIE
    Dec 28, 2000
    2,018
    well i was able to get these broken bolts out with the use of a Sears #5 bolt extractor.
    all is good. /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
