greasable bolts and bushings needed
Discussion in 'OffRoad Design' started by beater_k20, Mar 11, 2004.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    looking for greasable bolts, and bushings for my '79 K10 w/ 6" Tuff Country EZ Ride springs. i didnt see them listed individually on the website. what is the price of these parts? and availability?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You'll need:
    GU37012 main eye kit for TCI springs, $27
    GU37011 HD greasable shackles, $89
    GU37002 full greasable rear kit, $75
    That should do it.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the main eye kit, and the rear kit i understand. do i have to buy the front shackle kit in order to get the bolts for the front and the front shackle mount bushing? or can i order them separately? i'm planning on moving my shackle forward, and running a longer shackle, so your shackle kit would be useless to me at that point. thanks for the response, i look forward to doing business with you?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We have a greasable front bolt and bushing kit for just your situation. It's the greasable HD front shackles with no shackle plates. I think it's $55-$60, I'm at home and can't remember.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    my plans have changed a little... the TC springs are out, and a set of 52s are in. got prices and PNs for bushings and greasable bolts front and rear. i'll be running stock 52s front and rear, and would like to upgrade the upper shackle mount on the front to a 1/2" bolt.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Are you using the stock upper shackle mounting point? If so, we can get you a greasable setup or non, you're looking at a range of about $17.00 to $27.00 or so depending on what exactly you need.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i am using a stock shackle mounting bracket, although it will be moved. if im doing it, i might as well go all greasable. no sense in skipping 2 bolts when everything else is greasable. what kind of bushings do you use?
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    These would be our standard HD front shackle bushings which are the harder compound that we have built for us.
