greasable bushings question
Discussion in 'OffRoad Design' started by one, Oct 14, 2002.
  1. one
    one Registered Member
    Aug 31, 2002
    28
    redwood city california usa
    I just installed the greasable bushings in all corners on my 88k5 and 3 of them won't accept any grease. What's up? Are they too tight?(I torqued to specs). Any help greatly appreciated!
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    try to cycle the suspension and then try to grease again. Sometimes mine will not accept grease and you can flex it just a little bit one way or the other and then it will take grease.
  3. one
    Aug 31, 2002
    28
    thanks, I'll try that. I guess the pin hole for the grease is blocked somehow right now. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You could also put a wrench on the bolts and give them a twist to a bit different orientation, the hole on the bolt could be pinched up against the sleeve. If it moves a bit should work fine.
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    What type of grease is best to use? /forums/images/graemlins/tongue.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I just use whatever we have in the gun, usually a medium grade wheel bearing/chassis lube. That should work just fine.
