Grease fittings on 1/2 ton ball joints......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ColAdo82K5, Feb 28, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I'm pressing new joints into my flattops, and am wondering what to do for the top ball joint grease fitting. It comes with a plug, and the 45degree bend one that is seen in this picture...
    http://community.webshots.com/photo/61561424/121637254yQNhNn
    But, that fitting doesn't seem to clear the actual axle shaft and u-joint.
    What are the opinions and options ?
    Blake
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Put the zerk in, grease the balljoint, take the zerk out, and put the plug in. That's what I did, and as far as I know, that's all you can do. Just throw one of the grease zerks in your toolbox so next time you've got the front axle torn down you can grease them again.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, thats the way to do it! /forums/images/graemlins/waytogo.gif
  4. ColAdo82K5
    Feb 18, 2000
    789
    MO
    thanks !
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    My moogs have the upper joint fitting offset to the back (on the beval) and you can leave the greese fitting on all the time with no problems. The spicers I used to have did not have this set up though. /forums/images/graemlins/dunno.gif
  6. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Moogs I put in are same as az-k5s...you can leave the zerk in. But, both joints loosened up on me. I thought I had done it right. Why do they loosen up and is retightening the answer? Do they need more torque than the install specs say?
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You can also buy a low profile grease fitting that incorporates a spring loaded check ball. They require a special needle in order to grease them. I installed them on my front u-joints so I wouldn't have to do the plug removal thing.
  8. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Ran into the same problem. I picked up one of those needle grease gun tips and went around the joint boot. Not sure how well it worked though. /forums/images/graemlins/confused.gif
