grease front axle ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Aug 11, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    just above the front CV joint there is a ball joint? with a grease fitting that points down toward the CV joint, how are you suppose to get a grease gun in there? in fact the cv joint has rubbed the end of the fitting and worn it away
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Whenever you have to change your ball joints, get moog ones and the grease fitting will come out the side so you can grease it. I don't think that the ones you have should even bee there because of clearance. There is no way of greasing that one unless you take the axle shaft out.
    <font color=blue>Esteban</font color=blue>
    <font color=red>HAVE YOU EVER HEARD OF CHATA?
