Grease in bushings...where?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Dec 28, 2001.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    As some of you know, I am doing a shackle flip install. Since I had them off anyway, I decided to clean up my factory springs. They had all kinds of grime and rust and stuff on them. Since I was doing that, I decided to replace the bushings. I got a set of Energy Susp bushings from the local parts store, and they come with a little vial of lube. Question: where exactly should this lube go? On the outside of the rubber bushing...on the inside? both? Kinda a dumb question, but hey...give a quasi-noob some helpful advice. =) TIA!
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I put it inside as well as outside. Helps it slide into the spring and the sleeve slides into the bushing easier.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    coolio, thanks. =)
    J
