Grease is good
Discussion in 'The Garage' started by yellowK20, Jan 22, 2003.
  1. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    One of the guys that I run with has a 90 k-5 TBI350 700r-4 NVG-241 32" bfgs all stock except the tires and 4 core radiator Yesterday morning he calls and asks If I had any front end parts I said yes what do you need ?He said "i'm not sure" " i'm stuck in elpaso and my front wheels are locked up So i went into my shop and grabbed a set of bearings and races and seals for both sides on a whim I figured I'd take 2 spare spindles and hubs Then I jumped in the k-10 and drove the hour and a half to el paso and met him at the gas station he was stranded at I jacked the blazer up and and pulled down the drivers side Hub /forums/images/graemlins/shocked.gif man it was bad totally trashed the inner bearing was welded to the spindle and the outer bearing had destroyed it's self and the spindle (Glad I brougt spares) I asked my buddy when the last time he greased this thing He said "wheres the Zerk Fitting???" /forums/images/graemlins/mad.gif dumbass He's A jet engine mechanic. so I replaced the spindle and put new bearings and races in The my hub (the brake rotor on his hub was shot 1/4" groves on the backside sent him for new brake pads ) and reassemled that side moved over to the passenger side jacked it up and went to remove the The SUPERWINCH hub and stripped out 2 of the stupid a$$ taiwan allen bolts /forums/images/graemlins/angryfire.gif Out came the Hammer.....WHACK superjerk hub all over the ground those things aren't very stout got that side pulled down rather quickly the only thing holding that side on was the caliper !!!!! nothing left of the spindle,bearings ,races nothing !!!! so I replaced every thing on that side and put it pack together Duct taped over were the hub goes and hauled A$$ home /forums/images/graemlins/truck.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    You're a good friend to have...I hope your buddy learned something./forums/images/graemlins/eek.gif
    Rene
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    did you take grease with you?
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The guys a jet Mechanic??????? OOOOO Scarey /forums/images/graemlins/ooo.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/ooo.gif
  5. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    you are a very very good friend... /forums/images/graemlins/thumb.gif Even if I made it that far and they asked me about a grease fitting /forums/images/graemlins/rolleyes.gif i'd smack em' upside the head
  6. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Yeah the last of my good marine grade grease
  7. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    He's a good guy for the most part and I'd like to think he'd help me out if I needed it but the grease zerk comment was Way out there I did want smack him up side the head but instead i'll just tease him about it in front of every body It's a damn nice truck his tax return is going towards a 6-inch lift and 35" MTR's should look good when it's done /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    finally someone else who uses marine grease....
    I grease mine well but failed to regrease after sitting in some deep water for awhile, hub sealed water in and the hub exploded on my 250mile drive home from houston last week....grease boiled out and the bearings seized up just like that but only on one side.....I felt them going but tried to limp it home...didnt quite work...
    Comments like that always deserve to be brought up down the road at some point... /forums/images/graemlins/rotfl.gif
  9. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    I run alot of mud so I Really like the blue valvoline marine grade grease I also run all my vent lines between the cab and bed I used to have an air tank in the bed with a regulator and can pressurize the gear boxes and diffs with about 12 PSI to keep water out for deep water crossings seems to work well I got the idea from a fording kit for M-series Trucks but those kits use CO2 Insteadof compreesed air Not alot of water crossings in New Mexico so Don't use it any more /forums/images/graemlins/truck.gif
  10. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    A jet engine mechanic huh ? Now I remember why I hate to fly .
  11. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Yep on the F117 stealth fighter /forums/images/graemlins/truck.gif
  12. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    /forums/images/graemlins/wink.gifIt is all antifreeze and ball-bearings .
  13. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    MY little brother is a rocket scientist and I had to rescue His 2WD ranger.He was Suprised that a ujoint could be replaced on side of road. Was more suprised that vibe he had for nearly 2 months went away.Shadetree mechanics RULE. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif [He worked fro NASA on ram jet for mars ships while in college]
  14. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Proof that theres different kinds of intelligence /forums/images/graemlins/truck.gif
  15. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Hopefully some of that tax $$ will be spent on replacing the used parts, grease and a really big steak dinner...
    /forums/images/graemlins/grin.gif
    -Ryan /forums/images/graemlins/k5.gif
  16. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    the bearings and races were new Timkens the hubs were newer and the rotors were new the spindles were the only part not new he's going to buy all the stuff new and give it to me next week and he brought over 4- 30 packs of COORS today......... pretty fair trade ............. anybody want to party this weekend . He 's also going with me this weekend to help work on the new rig /forums/images/graemlins/truck.gif
  17. ZonkRat
    Jan 16, 2003
    1,003
    Good times with friends can't be beat. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  18. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    In Golden Colorado where the goats P!$$ clear It runs down the mountain and they call it COORS BEER /forums/images/graemlins/smile.gif /forums/images/graemlins/truck.gif
