Grease Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 11, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What kind of grease should I use to do the driveshafts?
    U-Joints?
    Other Parts?
    White Lithium? Or what?
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    I use a marine grease it helps to keep the moisture out.
    Brian
    82 BUrban 38.5's/6"lift/14B/10B/SM465/NP205
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    The marine grease is blue, BTW, and is available in tubes for your grease gun. Usual usage is wheel bearings on boat trailers.
    9/11/01..Never forget...Never forgive
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I use the same grease on my truck that I use on my backhoe. I figure if it's tough enough to protect a John Deere, then it's tough enough for a Blazer.
    I've used a couple different brands. At present I'm using Rotella something or other. It's made by Shell.
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
