grease seal in axleshaft??? help needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Sep 1, 2003.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    I'm trying to reinstall my front rotor, after having it turned, I swapped in an 8 lug 10 bolt. I don't know what year it was out of. I destroyed the inner grease seal (the one inside the inner bearing) trying to get it out so it could be turned. Now I can't find what part it is. the .5 ton seal is to small, the 1 ton seams to large. anyone know what year, or what vehicle came with those 8 lug fronts? or what seal I'm looking for?
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    well if its a 10 bolt, the 1 ton seal is out. If its 8 lug, the half ton seal is out. That leaves us with 3/4 ton. If its a 10 bolt, its a 78 or later.. I would try a 78 K20 front wheel bearing seal, outer. The "inner" seal will be the one by the ring & pinion carrier by the pumpkin. It shouldnt be that hard to find. let us know what happens
    mike
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Both 1/2 and 3/4 Ton use the same seal. Are you sure the seal area of the hub is not damaged from some kind of previous failure ?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  5. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    got it, it was a 78 that wound up fitting. thanks guys.
