greaseable bushing bolt strength
Discussion in 'The Garage' started by K5Chris, Jul 7, 2005.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    has anybody had any problems with the strength of greaseable bushing bolts?
    i'm fing tired of the squeek squeek squeek..... i put brand new bushings in my new front springs and lubed em up good with poly grease, and they still squeek like a bitch. any suggestions?
    where would be a good (cheap) place to get some decent bushings for rear 56's?
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I got a set for the front from ORD. They work great and completely got rid of the squeak.
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    If you tell me what the diameter of the hole in the center of the bolt is i can tell you the strength difference between the greasable and the regular grade 8.
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    i have herd of a couple of guys here that have broken a greaseable bolt, but it isnt a common problem. either there springs hit the frame from poor geometry and broke a bolt or they were flexed hard, probably with no limiting straps as to not over tweak the suspension, and broke one that way. i bought the ORD hd shackle kit with greasable bolts after i read that a couple people had broke them simply cause it does not seem to be a common problem. just my .02cents.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so ORD is where to get these for GM trucks rears ?
    how much are they ?
    link to these ?
    install difficulties ?
    thanks
  6. cbbr
    Jul 17, 2004
    14,681
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  8. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i just remembered something..... my dynomax headers are real close to my shackles..... i had to cut my current bolts down so they dont hit the headers. i dont think i can run those greaseable frront shackles at the rear spring eye bushing. guess i just need to slather them up with a whole lotta poly grease.
    i found these from daystar last night. http://www.suspensionconnection.com/cgi-bin/suscon/KG61001G1.html
    just another option. they look pretty strong.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ORD bushings are Daystar.
  10. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I'm running Dynomax headers and greasable shackles. So far, so good. It is real close, but they haven't hit yet during moderate wheeling.
  11. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    yeah i know but the shackle is different........ and so is the price.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    3/8" x 2" flat stock will make you some, not only cheaper, but any length you want too.
