greaseable sway bar bushings?
Discussion in 'The Garage' started by Cornfield creations, Oct 30, 2005.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Anyone know anyone who makes greaseable sway bar bushings? I ran a search and came up with nothing on the sway bar but all other bushings. Is a greaseable even needed or would a urethane bushing be good enough from energy suspension?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Just drill a 1/4 hole in the bracket and screw in a zerk fitting
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I got mine at Autozone a couple years ago for like $15 or so. Never had a problem with them. :D
    Rick
  4. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Is it even necessary to get greaseable ones? Or should I just get urethane?
    I mean it is just a sway bar
  5. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    :D :D wtf is a sway bar? :D :D
  6. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    thats now most of us feel...once you go beyond stock leaves (even adding an AAL to the stock pack) its generally gonna be more than stiff enough to run without one...
  7. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Well I only have a 4 inch suspension and I drive it quite a bit yet on the road.
  8. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    mine is 100% daily driver. yes a mall crawler.
    havent had the swaybar for months. very little diffrence with my 4" TC
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Try taking the swaybar off and drive some. It adds flex to the front without too much body roll with 4" lift and bigger...
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Same here . I would never flex with them on though , I use disconnects . The bushings seem skinny to me .
  11. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I forgot to mention that, I have homemade swaybar disconnects on mine. It gets unhooked anytime I go 4wheeling. The greaseable bushing makes it much easier to move the swaybar up and down to hook it up or unhook it.
    Rick
  12. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Energy Suspension makes them. Here is a link to the page from their catalog. The "(29)" footnote indicates the greasable type. http://www.energysuspension.com/pages/c4wd1.html
    You should be able to order these from Summit Racing Equipment, or Jegs, etc.
    I've done a lot of suspension design for high-performance (on-road :rolleyes: ) racing, one thing that people don't realize is that switching to urethane bushings that are not greasable can be a big problem. Rubber bushings allow some amount of twist along the axis of the bolt, urethane do not (well, nearly none). This can cause trouble because the original design was set up including this natural twist ability, and if you take it away, it will not perform as intended. So the greasable type allow the twisting to take place again, but make sure you grease often, because urethane is not porous and will not hold lubricant. It will quickly expel grease from the inside. Greasing monthly or bi-monthly is not too often. (Now, I know it's not AS BIG a deal in our 4x4s, but for those of you unfamiliar with performance suspension design, everything is figured in together to 1/100ths of an inch and 1/10ths of a degree. Urethane bushings make huge changes to suspension performance that must be adjusted for in other components for optimal results.)
