Greaseable vs. Non-greaseable u-joints
Discussion in 'The Garage' started by JK5, Apr 2, 2002.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just bought 35-spline outer axles for my D60, I have found that non-greaseable u-joints are stronger and I plan on using them on this project! What do you think? Should I use Greaseable or Non-greaseable? I was planning to use Spicers, what brand of u-joint do you use?
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    You are correct that the non-greasalbe are stronger than the greasables...I would have to say go with the non-greasable and just plan on rebuilding them a little more often, esp. if you run mud and water a lot...
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    They may be a little stronger...but the greasable at least you can maintain them better. I've found the 'sealed' non greasable U-joints usually aren't that sealed and dry up and fail faster. At least with greasable I can pump new grease in at regular intervals and especially after wheeling.
    Rene
  4. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    I use CTMs U joints. I haven't had a problem with them yet. They're tough as a two dollar steak. A little on the expensive side. I woop the heck out of mine and haven't had a problem yet. I did have to get new 35 spline stubs two weeks ago. I am starting to think the CTMs are too strong. Yeah right!!
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    how long have you run them?
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I talked to a driveline specialist yesterday about this... i had to have a u=joint changed... he charges me 15 bucks to put in a neepco u-joint installed and the part for 15 bucks! the part lists at 15 he does it for 10 bucks... install is 5 bucks...
    Anyways, I asked about greasable and non greasable... He said they are weaker but the weakness you loose going with non greasable when your playing in the mud/water is worth the difference. You get one grain of sand in a u-joint cap.. it'll tear the needle bearings up in a matter of miles... if you can pump grease through them when you get off the trail, well it cleans out the u-joint much better!
    So when I buy u-joints I buy the greasable ones for my u-joints and solid for the front end... if I break a front axle u-joint... I can still drive home... and i need the extra strength.. but the drive shaft... i want to be able to flush out...
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I personally can't see any time that I would use a non greasable.
    if the pin hole grease passage is the make or break point for your ujoints it is time to step up to bigger stuff
    I dont like disposable parts
  8. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got one application (that I know of) where I like non greasables - the funky double-cardan joint on some Fords. There's no way to get a grease gun on them without dropping the shaft, and it's the front shaft anyhow - the better quality sealed are the way to go there IMO.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is one where I would want a grease option
    CVs are $$$ so anything I can do to extend its life I will try
    greaseable CVs usually use a needle type nipple that can be reached with effort
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I had a brilliant idea on it of putting in a pipe plug in place of the zerk - I couldn't get anything on it to get the plug out though. Now I need to invent something like the self sealing top on a drug vial to grease them. I might even make a 30 or 40 cent profit/forums/images/icons/smile.gif
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the needle style nipple is as good as it is gonna get
    like the ones used on CTM caps
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You're probably right - I came up with the self sealer idea after looking at the little oiler cap thingies on my lawnmower - they don't seem to let anything past them, but I've never seen anywhere where you can just buy these fittings.
