Greasing U-joints
Discussion in 'The Garage' started by MTBLAZER89, Dec 14, 2005.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK got a question. Can you guys grease your U-joints while they are installed? I can't:mad: It's a PITA having to take the shaft off to grease them. I can almost get to them, but the yoke is just in the way by 1/4" or so. Can I get a different style zerk? I know the grease fittings on our aircraft take a big needle style grease tip. I could also grind a little notch in the yoke, but thats prolly not good for it, or do I just need a different tip for my grease gun?
    My grease gun looks like this with the soft hose.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    take out all your regular zerks and put in needle fittings, makes a difference :thumb:
  3. sweetk30
    Nov 1, 2004
    25,555
    548
    horseheads , ny 14845
    also there is a correct way to install the cross in the shaft. grease hole to the center of the shaft to help clear the yoke better. most i see are in backwards and would take grease if in correctly. and i have used a needle greaser on regular style zerk heads just push in on the ball. then pump.
  4. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Or next time get U-jts with the grease nipple on the cap instead of the cross. That's what I did.
  5. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Autozone makes a fitting that installs onto your grease gun it was like $8 or so. I will see if I can find a pic of it.
    here it is
  6. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    I use a grease needle to get to the hard-to-access zerks. I'll post up a pic tomorrow.....
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah they are oriented correctly, but the yoke is just barely in the way.
    OK thats what I need then, and the other tip pictured above for my grease gun:waytogo:
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yep, put needle zerks in mine. Works like a charm.
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    :waytogo: Sweet thanks don't know why I have waited so long to ask this question:D
  10. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    While we are on the subject, whick grease do you guys use? I have been using some cheap grease but want to put some good grease in all my joints sometime soon.
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You can grease a normal zerk with a needle fitting... Requires bit more hand-eye coordination, but I do it everyday. Prolly 10-20 u-joints a day. :crazy:
  12. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I use the regular cheap grease and make up for it with frequent applications!:D My rig is off road only, and I grease everything before or after every trip. I try to do it right after, because I usually push water out with the old grease.
    I do have a separate gun with high temp grease for the trailer wheel bearings though.
  13. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    I use marine grease it seems to hold up better to me. I would rather spend a little extra on grease then to keep replacing u-joints, etc.......
  14. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I saw a reveiw someplace that said to use the "green marine grease".
    Think I will look for it next time but for now I use el chepo greaso.
  15. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I have a needle with a bend in the tip for just such occasions, it comes in pretty handy.
  16. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I do not know the actual name for the green marine grease but in the Navy we call it Tourmaline. It is specifically designed for saltwater applications and does not crystalize like other greases when salt gets in it.
    Ira
  17. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    I used to work a motorcycle shop in Cali. I would buy the Yamaha marine grease. I believe any marine grease from boat store or motorcycle shop would hold up best IMO.
