Great price on Eldo calipers
Discussion in 'The Garage' started by TX Mudder, Mar 6, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I was price shopping on the Eldo rear calipers for a 14 bolt. Autozone wanted $150 for both plus a $140 core!
    I checked Hi-Lo O'Reilly. They are only $56.99 plus a $15 core, each.
    Just wanted to pass the word along...
    -- Mike
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    loaded or unloaded and what brand?
    At that price it is cheaper for one of you get get them and mail them to me,LOL they are $170 for a loaded pair through my work, plus the cores /forums/images/graemlins/tongue.gif .
    -Jeremy
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    By loaded, I assume you mean with brake pads??
    They do not come with brake pads, but I bought a set, Albany brand, from Autozone for $17.99 for 4 pads, enough for left and right.
    I am supposed to be picking them up after 5:30pm (shipped them from the downtown Houston location to my local location.) I'll see if they have a brand or anything on the box.
    -- Mike
  4. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    Do you know if they are coming with the e-brake lever and return spring?
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I went to go get them and....
    no lever or spring...
    I ended up returning them since I can't use them.
    Can a little spring and lever really be that expensive???
    It doesn't look like a lot. All it was missing was the spring and the lever. A similar spring could be located fairly easily.
    As far as the lever, it looks like you'd drill a hole in a piece of metal, use a torch to make a lazy S bend in the lever, and then make a place at the other end of the lever for a parking brake cable to attach.
    Hmmm....
    -- Mike
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Can you put this little contraption on a 3/4 ton GMC front caliper in order to run Ebrake?
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The eldo caliper has a threaded rod that sticks out of the side of the caliper and is what the nut on the lever in the picture above bolts to.
    The gm front calipers don't have that.
    -- Mike
  8. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I check Advanced Auto and they only wanted 26.95 + 10.00 core.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Are you sure you asked for the 76-78 rear caliper for an Eldorado? That sounds like the price for the later model caliper, which is MUCH easier to find.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I don't think that any of them come with those 2 parts. /forums/images/graemlins/frown.gif And GM discontinued the lever many years ago. /forums/images/graemlins/angryfire.gif That little lever is made out of some VERY strong steel. I don't think you could make one out of mild steel that wouldn't bend when the brake was set. /forums/images/graemlins/frown.gif
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I am pretty sure, but i will check.
  12. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I must have missed the were you guys said what loaded is? Can some one fill me in? Thanks
  13. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    This might seem a little dishonest but, how manny parts guys at autozone type places even look to make sure you have the proper part for a core? The autozone places around here have mostly part time employees who could care less about this sort of thing. I'm sure you could pass off a set truck calipers or some other application for a core.
    Just my evil genius at work. /forums/images/graemlins/thumb.gif /forums/images/graemlins/angryfire.gif
