Gremlins are in my truck
Discussion in '1936-Present Suburban' started by eatsjeeps, Jan 3, 2003.
  1. eatsjeeps
    eatsjeeps Registered Member
    Dec 7, 2002
    23
    Portland Oregon
    Well this week my window on drivers side won't roll all the way down. I can occasionaly roll down windows on pass side but not always.
    And to top it off My Door lock got stuck and I had to climb over the console and out pass side and repeated process after paying for fuel. Why and is this common?
    It is an 89 silverado package. /forums/images/graemlins/burb.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Those little switches on the door sometimes die. they get old and gummed up. You can clean them but sometimes its easier to just replace them.
  3. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    i had the same problem.what i did was pull the door panel and grease all the window cranks and arms etc.and clean and dielectic grease the motor and switch connections and check the window grounds.
    the windows are faster but still slower then stock.
    just changing the switch is the easiest solution but i found in all my doors the window grease had become hard and really sticky.
    but then again the bottoms of my doors are open to the world.
    goodluck
  4. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    that happened to my sub, the front driver's window only went half way up, a long time ago, before i started workin on trucks and my mom and dad put it in a shop and got it fixed.
