Grey/Blue smoke valve stem seals?
Discussion in 'The Garage' started by rafterman191, Oct 14, 2006.
  1. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    Upon cold start up and higher rpm running until operating temp reached, I have a grey/blue smoke from the exhaust. The guy I used to work with did a head gasket replacement on it but said the valve seals didn't "feel" bad so he didn't change them. Sound like the problem to anyone? How hard is it do just change the seals? Sweet squirrel stew!! Oh yea, it is using up the oil pretty quickly or I would not be too concerned. I would say easily a quart per 1k miles.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    using that much oil i would say it is more than just the seals, the guides are probley worn also, just the seals only tend to blow smoke on start up
  3. rafterman191
    Aug 28, 2006
    54
    Indiana
    Crap, that would be alot of work. Replace heads? Would be a better option? Or replace motor even. Or am I making too much out of it? Anyone install sleeves in their valve guides? Any other fixes?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can have sleeves installed in the valve guides, you might want to pull the valve spring off a valve or two and check the side play with the head on so you know for sure if it is the guides
