Grille for '90
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Crash90K5, Mar 21, 2000.
  1. Crash90K5
    Crash90K5 Registered Member
    84
    Santa Clara, CA.
    Grille for \'90
    Found a cool grille in the latest LMC Truck catalog, but the darn thing only lists Blazers through '87. Then I called and the salesperson says it'll fit 83-88. Ok, I know the 89-91 has a different front clip, but is that limited to the headlight and turn signal bezels? Is the grille the same?
    Shawn, is this something you could answer? You have a newer front clip on your 87, right?
    Thanks all,
    [​IMG] <font color=blue>Crash90K5</font color=blue> [​IMG]
  2. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Re: Grille for \'90
    what does LMC stand for? There might be somethings worth looking into at that place. thanks
    "What me get stuck? NEVER!!"(Famous last words)
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Re: Grille for \'90
    The salesman is probably correct. Most grilles (center portion)from '81-'88 will interchange. You are correct in stating the '89-'91 is different. the newer grille requires the use of a different radiator support, headlights, turnsignals, and headlight bezels. No parts from the previous years will work on the '89-'91 grille. You can install the newer grille on an older ('73-'88) Blazer with some modifications. I am writing a '89-'91 grille upgrade article for this site. I will have it submitted to Steve soon and you can read all about this matter. I have not seen any aftermarket grille inserts for the '89-'91 grilles yet. Let me know if you find one.
    <font color=red>Mudzer</font color=red>
    1978/91 K5 Blazer
  4. Crash90K5
    84
    Santa Clara, CA.
    Re: Grille for \'90
    Long Motor Corporation
    Check 'em out at http://www.lmctruck.com They don't have an online store, but you can order a catalog from them.
  5. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Re: Grille for \'90
    Sorry I didn't respond to your post earlier. The 89-91 grill is shorter since the headlight and turnsignal bezel is larger compared to the pre-88 years. They do make some custom grills for 89-90. I'd get a copy of Truckin magazine and look at the adds. If you're set on that grill in LMC, you might be able to chop the ends off but I can't guarantee it will fit perfect.
    If anyone is planning on installing an 89-91 grille which requires a few parts, Neil (Mudzer)has done an excellent job on an article about this that will be posted on off-road.com today.
    Here's the link:
    http://www.off-road.com/chevy/tech/grill
    Shawn
    87 K5
