Grills
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Feb 15, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have 82 k5 what grills can i swap in, just by replacing the grill nothing else. I want the blinkers in the grill not the bumper
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you are near yuma AZ, i can fab it up for you. no swap needed.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    The break in the radiator supports is 73-80, 81-88, 89-91.
    So you should be able to put in any grille from '80-88. The only major modification I believe would be doing some electrical work to move the turn signals to the grille.
    Shoeless
    '88 K5
  4. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I must of miss read the title! No girls in here!!!!!!!
    It is 81 through 87. And if you are using the wiring harness out of the bumper the pigtail are wrong for the lights in the grill. The bumper type pigtails have the wires coming straight out and it will interfer with the core support. The correct pigtail should have the wires coming out at a 90 deg. angle. Where the lights in the bumper in 81 and 82 or just 81?
    built not bought
  5. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    Or is it 81 through 88+. I was thinking of p.u. grills!!!!!!
    built not bought
  6. shoeless
    Nov 1, 2001
    99
    N/A
    It is 81-88, 89-91 use a different core support, and headlight retainers. Yeah like I said the only major mod will be replacing pigtails.
    Shoeless
    '88 K5
