grinder question
Discussion in 'The Garage' started by 84gmcjimmy, Dec 21, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I really need to fix my grinder, it's been held up for months because I can't find the connecters. On the end there is a little connecter with a hole in for the screw, I got 2 sizes but they are both the wrong ones. Can I connect the old wires (that have the connectors on) with the new wire I am using for a cord? The way I would do it is strip the plastic sleeve off, and twist the 2 wires together, then sauder them together. Will that be okay?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    please describe problem better?:xmas:
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    you can patch in your new cord to the old one using some butt connectors or solder them. just make sure you shrink tube or black tape them up individually.. not the recommended method, but it'll work...
    if the ring terminal connectors you got for the new cord are too small, you can carefully ream the hole out a little to fit a bigger screw..
    if these
    are what you need, and don't have the right size, they should be readily available at any auto parts store... try to get the good ones with built in glue and shrink tube. much better than the hard plastic ones... i use http://www.dearborn-cdt.com/ products for most of my electrical connectors.. quality stuff.. or you could check out Painless, i'm sure they have em....
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL sorry...
    ummm a few months ago I cut the cord off the 5" grinder because the cord was wrecked. So last month I went and got a new plug and cord for it from home depot. I come home and go to fix it and I need 2 "ring connectors" to attach the white and black wire to the grinder. So I bought some connectors yesterday, but they are the wrong ones because the hole for where the little screw goes is to big. I needs a smaller hole. SOooooo... can I (is it called splice?) the old wires with the new wires until I can find the right "ring connectors" ? I need to use this grinder because I have (5) 5" cut off discs, and NO 4.5" cut of discs.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I got connectors like the ones pictured, but the hole is too big, so when I put the screw through it onto the grinder, it wiggles a whole bunch. The place I got them only has the big ones, and small square ones with a TINY hole in. Any other place will just hose me with the prices...
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes you can splice ans solder the wires together, just make shure to shrink wrap them:xmas:
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What is shrink wrapping? I have black electrical tape, will that work?
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hell, send me your addy and i'll mail ya an assortment... got tons of that stuff... what gauge wire, 14? you want blues...
    either way, yes a splice is fine.. ugly, but functional..:grin:
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes just wrap it up real good, shrink wrap is a heat sensitive tube that you slip on a splice heat it up and it shrinks to form a thight seal over the wire:xmas:
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I don't know what guage of wire it is, I think it's 16 or 14, i'm not sure...
    How much money will it cost? I'll PM you my addy in a few minutes...
    surpip, okay I will wrap it up real good. I'm just going to do this for a few grinds, until i can find the right connectors.
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    freebie, don't worry about it... and yeah, black electrical tape is fine...
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    dont worry about it to much dude, ive had to do this to alot of skill saw cords, that stupid people have cut through, they hold up for a long time with no problems if done right:xmas:
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow! That's awesome! Thanks sooo much!
    Well, I got it spliced up, and got it all put together (took me an hour and a half; had to take it apart 3 times because I kept forgetting to put some things on)
    I fired itt up and didn't die, so thats a plus, but when I turn it off, it keeps going. What have I done now???????????
  14. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Find you a couple of washers to put under the screw heads, then thru the connectors and tighten it up
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    The screw is only long enough to go through the connector, and screw into the body. It's a tiny screw.
    I ended up splicing the old and new wires together...
