Grinder to Buffer conversion?
Discussion in 'The Lounge' started by Cavalry, Jun 14, 2002.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I am looking to buy a buffer (10" or so) Probably will be going with Dewalt or Makita. Can I buy a grinder and just get the rubber backing disc etc (or vice versa) I know the buffer has variable speed controls where a grinder dosent. I just dont want to buy 2 $200 tools if I can buy one
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Most of the grinders have same thread type shafts so you can swap disks (grinder, rubber disk for pad etc....)
    You should look for one that has a variable speed adjustment to limit max RPM. I have a Hitachi that you can adjust on-the-fly with your thumb (on the trigger finger hand). Most grinders will run at an RPM that is too high to buff with IMO.
