Grinding 1 Ton calipers, for 15" wheels, again probably...........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jwduke, May 4, 2002.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Grinding 1 Ton calipers, for 15\" wheels, again probably...........
    Well I'm at that point, i'm trying to fit 15" wheels, with a 3 1/2" backspacing on a 1 ton axle. I've tried doing searches, but most things come back with nothing. I tried Wayne's "Mighty Mouse project", and get the dreaded blue screen. I guess my question is, where in the caliper do you grind? The top? The front edge? All of the above? Help guys! And, again THANKS!
  2. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    Re: Grinding 1 Ton calipers, for 15\" wheels, again probably...........
    I have 15s on a dana 60 with 4 1/2 backspacing. you will need to grind on top and the front of the caliper also you will have to grind on the backing plate alittle. baddog posted a bunch of pics on this in the garage area so i would check there it was awhile back so you might have to search a bit
  3. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    I emailed you the site that used to be up
  4. jwduke
    Aug 25, 2001
    721
    New problem.... I've got a Dana 44HD, seems like the place the grinding needs to be is where the bolts hold the caliper on are. I'm beginning to wonder if it is possible to mount 15" wheels on a Dana 44. the caliper is different than a Dana 60 caliper. It is probably the same as a standard 1/2 ton.
  5. bmwsma
    bmwsma Registered Member
    Nov 17, 2001
    67
    Chalfont, Pa
    Can you post the site? I'm gonna be in the same boat soon.
  6. dysphemism
    Oct 26, 2001
    667
    Fremont, CA
    sites down but I emailed you the zip file of the site.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    <a target="_blank" href=http://www.members.cox.net/russhuffman/grinding/calipers.html>Here</a> ya go, I gave up and reposted it to the web...
  8. jwduke
    Aug 25, 2001
    721
    Well, I decided that I was going to grind till either the wheel fit, or there was no caliper left! Well, I ground &amp; painted it like stated in the article &amp; it worked. I still have plenty of material left. I was kind of worried about the bolts that hold the caliper on, but they are threaded on the back side. Looking at them, on the front side, they look like they basically hold the pads down, &amp; from sliding up. I would like to thank EVERYONE who helped me! Thats why ColoradoK5.com is the greatest! All of the super contributers, who have done it before! Again, THANKS!!!
