Grinding leaf spring ends
Discussion in 'The Garage' started by 1987Chevy, Jul 29, 2006.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    A friend of mine knows a guy with a suburban on 8" front springs. The guy took an angle grinder with a flap wheel and ground some more taper into the ends of the leafs in the pack. I've never personally talked to this guy but according to my friend this gave this thing a real cushy ride. I was wondering if any one else has ever heard of this and what the cons would be besides weakening the ends of the leafs.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have heard of that or rounding the end of the springs. My Superlift rears are rounded, but I don't know if it helps or not. I can't imagine it does a whole lot. Spring rate determines the ride quality.
  3. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    'Pends on how much you taper. I imagine if you tapered 'em back a few inches, they're be softer. Kinda add a progressive effect. Heck, I might try it.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Well made springs come with the ends tapered. I imagine you would have to have some serious gouging of the underside of the leaves in the packs going on for homemade tapering of the spring ends to have that much effect on ride quality
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i smooth the ends of leafs I use on my K5. I doubt it changes ride height much, but it does help with spring bind and reducing friction between the leaves.
    j
  6. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    thats supposedly what the guy says it does is make kinda more progressive by lowering the rate
  7. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Pretty simple...the spring is what is holding the truck up, them more you move, the softey it will get. Also reduces the area of friction at the end of the leaves.
  8. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Call up deaver and ask them why they do it. I was reading an article in 4wheeler about deaver. Deaver says they taper the ends of the springs to reduce pack bind and to get away from having to run teflon pucks between the springs. The teflon pucks can end up with dirt and rocks between the springs helping to create more friction. Also, the only thing that will change ride characteristics is to reduce the size of each leaf spring. If you look at deaver packs notice how they have more that are thiner? This allows for a more linear compression rate and a smoother ride. I doubt that tapering your spring is going to help much in reducing spring rate unless your springs are binding and gouging into each other.
    ~Brian
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Leaf Spring spring rate is dependent on the width and thickness of each leaf in the pack. Changing either changes the total spring rate.
