grinding noise from my front hubs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Feb 27, 2001.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I have a stock 77 k5 that makes grinding noises from the front hubs. It only dose it when I let off the gas to slow down, the transfer case is in H, and the hubs are unlocked. I have to drive it with the hubs locked all the time to stop it from grinding. Has this happend to anyone else or dose anyone have any advice for me? Thx
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> if you have the manual hubs in there, take em out and replace them with WARN premiums.</font color=purple>
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    ITs hard to say. I'd take them out and look to see where the grinding is happening. If its a true metalic grind you will be able to see where it is coming from.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  4. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Have you checked your wheel bearings? Mine was making an awful racket once, and you could grab onto the top of the tire and feel the play (at least an inch back & forth) as the "spindle" moved in the end of the inner hub
    I'd start there...
