grinding noise from tranfer case or tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Dan, Nov 26, 2002.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    when I let off the gas I here grinding when I push gas no grinding sounds like transfer case or tranny Help!!!!!!!
  2. Hank75
    Hank75 Registered Member
    Nov 30, 2000
    31
    i have the same issue with my truck? on gass no noise off gas grinding. anyone know whats going on?
    i have 350 th350 203 75 blazer
  3. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    havent got to play with it much i guess it could be drive shaft anyone help
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    at all speeds or only low speeds?
    What xfer case do you have?
    208.... hmmmm
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Dan: Check your t-case shifter linkage adjustment and/or t-case mounts. The 208 shifter mounts to the floor. When under load the t-case will raise up slightly, especially if the mounts are worn out. If this is happening and the shifter is out of adjustment it may be pulling on the lever on the t-case and trying to go into 4wd when it comes back down under decceleration.
    Hank: Has your 203 been converted from part-time? If not, it might be that the chain is loose and slipping when you let off the gas.
    Of course there could also be some other problem with either truck such as a worn differential or gears transmitting noise through the driveshaft. Or it could also be worn ujoint(s) making noise.
  6. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    thanks I will check all the above /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  7. Hank75
    Nov 30, 2000
    31
    thanks for the reply
    my 203 has been converetd to partime
    gears are brand new and ujoints will be replace soon hopefully that does it
  8. scoobydoo2684
    scoobydoo2684 Newbie
    Nov 27, 2002
    california
    I get a grinding noise as well except it happens when i shift into reverse. after about 5 seconds it stops. it will also do it at random times while driving. /forums/images/graemlins/confused.gif
  9. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I had the exact same problem with my truck.I thought it was the tranny(4 speed) so I tore it out ans replaced it with an auto and a new transfer.Low and behold I finished up the install and the noise was still there!The pinion bearings were shot.The noise transfers up the drive line really well and its hard to tell where it was coming from.Just be sure to check your rear end before tearing into anything.Very expensive oops,but I learned alot......
