grinding noise in 4x4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigdaddy89, Sep 15, 2000.
  1. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    A friend of mine has an 88 with the np208 transfer case. He says that when he puts it in 4x4 it makes a grinding noise that he thinks is coming from the transfer case. I haven't heard it myself yet, but can anybody give me some idea's where to start. I don't know much about these cases.
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Check the ATF level in the case and check that nothing is making contact with the front driveshaft. Those are easy (cheap). If the grinding can be "felt" in the shift lever, the case probably needs professional help (expensive).
    [​IMG] Semper Maintenance!
