Grinding noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Aug 17, 2003.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Just changed the pads and put some permatex disk brake quiet on it. When I went down a small hill they squeaked and then I heard a grinding sound. Didn't see any marks on the rotors, would bad wheel bearings cause the grinding sound? As far as the brake squeal goes, has anyone had better luck with another product? I heard the CRC stuff works good??
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    did you install new pads without resurfacing the rotors? and the disc brake quiet, you put it on the back of the pads, right? oh and what brand pads did you use? usually aftermarket pads are noisy to begin with, esepecially the lifetime warrantied ones because they're so hard..
  3. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Didn't resurface the rotors and you're right, I did use the lifetime pads... could that be the problem?
  4. Confedneck
    Nov 1, 2002
    5,236
    its possible..they're so hard and theyre trying to grab a glazed surface..its really hard to diagnose stuff like this over the computer...but did you grease the slides that the holes in the brake pads go over?
