Grinding rear driveline
Discussion in 'The Garage' started by BrownK5, Jan 10, 2006.
  1. BrownK5
    BrownK5 Registered Member
    Jan 8, 2006
    25
    gresham,OR
    i lifted my 79 6" less then a week ago and busted my 2nd u joint today. i looked at the joint and it appears that the needle bearings came out of one of the sleeves and is siiting at an angle instead of straight. it looks like the driveline is hitting the tranny bolt up spot, puching the joint out everytime they hit. i heard to solve this you have to grind both down so that they do not hit anymore. has anyone done this?
  2. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    im a bit of a novice at truck driveline angles but it sounds to me like the 6in lift has put to much of an angle on the driveshafts and is overstressing the u-joints. hopefully someone more knowledgeable will post soon, but i believe a fix for your problem is to shim the rear axle to correct for the angle and to lower the transfer case to aleive the problem.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Pics would be helpful. The above post is probably correct. Are you putting the "c" clips in the caps? Are the ears of the dshaft and the tcase yoke hitting?
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    is your t-case dropped at all? That will help with angles/grinding issues. I had them when i had 7" and did grind out the d-shaft some to resolve those issues. Ive never broken a joint but most of what i do involves mud/dirt/grass and not rocks or anything with real traction.
  5. BrownK5
    Jan 8, 2006
    25
    gresham,OR
    my transfer case is in the stock location. my 4" blocks are angled, so the pinion isnt to bad, the rear u joint has no problems at all. this is all on a daily driver/ weekend wheeler. thanks for anymore help, i have to get this thing back on the road asap.
